Spots with High Beams? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 02-14-2010, 08:02 AM Thread Starter
GreenAmphibious's Avatar
wiring up my IPFs today. There is a fused cable that is supposed to splice into the hi beam (I am guessing this shuts the IPFs off if I flip the hi beams on) any adverse results if I leave this out? I'd like to be able to roll highs and IPFs at the same time. Thanks
2015 JKU Sport Virgin
GreenAmphibious is offline
post #2 of 14 Old 02-14-2010, 01:27 PM
Err...that doesn't sound right
You should have fused cable for the main power that should run directly to your battery, and a smaller unfused cable that switches the relay.
The smaller cable is normally spliced into the high beam so that the spots and hi-beams come on together - ie power to the high beam circuit activates the relay, which then in turn activates the spots.
Miraz is offline
post #3 of 14 Old 02-14-2010, 01:42 PM
I agree wih you that the smaller cable is used to trigger the lights on with the high beam circuit. But on my KC Daylighter harness there is a small (1.5 or 3 Amp - I can't remember) fuse on the trigger line.
Regards, Tim
Timbo2000 is offline
post #4 of 14 Old 02-14-2010, 05:39 PM Thread Starter
both lines are fused. The one going to the batt and the one running tho the headlight
post #5 of 14 Old 02-14-2010, 05:43 PM
oz97tj's Avatar
You don't have to power the lights that way. I just wired mine up direct and have a on / off switch. Then I'm not splicing into my factory wiring.
Also, my spots are bright enough that even if I turn my high beams on,it doesn't really make a difference so I just run my lows with my fogs so I have a wider spread of light up close and then the spots reach out for long distance.
oz97tj is offline
post #6 of 14 Old 02-14-2010, 08:51 PM
dewayne's Avatar
I ran the swiitch to relay off high beams that way they come on with highbeams and go off on dim. Also upgraded driving lights to 100 watt bulbs REALLY made a BIG difference in how well can see .
2008 Unlimited X,38x15.5 x18 Mud Grapplers, 6sd,4.88's,4"Rough Country ,Quick disco,Cut fenders
On and On and On,
Is it really ever done?
dewayne is offline
post #7 of 14 Old 02-15-2010, 07:07 AM Thread Starter
OK that was what I was looking for... thanks. I want to control all my lights when I want them.
post #8 of 14 Old 02-15-2010, 12:38 PM Thread Starter
OK got everything wired up minus the fused wire that goes to the HIGH beam wire of the headlights and no worky so I am guessing that fused line is needed to provide poser to the spots switch.... now just gotta figure out which wire in the back of the headlight is the HIGH beam
EDIT: Just found this link and wired it straight to the batt + ON DEMAND lighting
https://www.jkowners.com/forum/showth...adlight+wiring
post #9 of 14 Old 02-16-2010, 05:20 AM Thread Starter
oh dayum with the 100watt bulbs these beyatches are bright! I was just looking for someone to cut me off this morning
post #10 of 14 Old 02-16-2010, 10:50 AM
oz97tj's Avatar
I like the douchers who refuse to dim their lights. Then I turn on my spots...
oz97tj is offline
post #11 of 14 Old 02-16-2010, 07:09 PM
dtcc687's Avatar
i love when people cut me off, ill give them a flash of 130 watts
Steel Blue 07 2dr
Jersey
Crew
dtcc687 is offline
post #12 of 14 Old 02-20-2010, 08:41 PM
jeepRcreepR's Avatar
I would like to do the same thing. Do I just strip off the casing of the yellow wire on my 968's (the wire that is suppose to connect to the high beam wire) and rap it around the + terminal a couple times?
jeepRcreepR is offline
post #13 of 14 Old 02-21-2010, 06:20 AM Thread Starter
I crimped a wire eye to the end and attached it to the + bolt before the post. Same spost I added my CB and winch I see yo uare in bradenton. If you need help bring the chit on over (I am in carrollwood) and I'll help ya out. CB/lights/winch.... got it all mapped out now. I alos have all the little shit needed to get it done.
post #14 of 14 Old 02-21-2010, 02:14 PM
I have some friends in Carrolwood. That's not a bad drive, I'll have to keep that in mind. Thank you for the offer. After looking at my battery and what was hooked to it, I figured I needed to get a wire eye. My friend and I did the wiring after we got the rack on the jeep. On the first try they came on using the (+) terminal. I have some picks i'll post to the Wildboar rack thread. Now I just have to wait for my new lens to come in for the one IPF light that was shattered and another set of light tabs that never came and I'll have all 4 lights put on.
