Aftermarket switches to fit in stock location? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 02-13-2010, 01:48 PM Thread Starter
upalms's Avatar
We have a loaded Unlimited X, and plan on a set of driving lights, I see the Daystar pannel that fits under the heater controls and holds 4 switches, but I only need one, 2 max. Does anyone make a switch to fit in the stock location, like where the Rubi disconect switch would go?
On a second thought, when we replace the front bumper, is there any way to run a set of aftermarket driving lights from the stock switch?
Thanks,
Todd
upalms is offline
post #2 of 4 Old 02-13-2010, 02:39 PM
Just rig the driving lights up with a relay switched from the high beam...then you don't need any extra switches - or if you want to get fancy then run a second relay off the fog lamps so that the driving lights will work only if you select the fog lights + high beam.
Miraz is offline
post #3 of 4 Old 02-13-2010, 07:43 PM
jacktuttle's Avatar
That could get interesting.... The stock fogs only work with low beam or parking lights....
jacktuttle is offline
post #4 of 4 Old 02-13-2010, 07:53 PM
You may want some additional control over the lights as well... I had lights that had both a switch and hooked to the highbeams... this allows your high beams to work without the driving lights coming on... but I had to have the high beams on to have the driving lights on...
2012 Silver JKU Rubicon
5 speed auto, 4.10s
Riptide is offline
