Recon LED turn signals - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 11-04-2014, 05:26 PM Thread Starter
I recently installed the recon led turn signals in a 2013 wrangler. I have connected the resistors which stopped the hyperflashing but (with or without the resistors) the turn signals do not work while the headlights are on but they will stay lit just don't blink. Headlights, tailights and side fenders lights have been switch out to led too. Went to replace the flasher but it seems to be built in behind the speedometer after I pulled apart the whole dash. Does anyone know a fix to this issue?
Jk826 is offline
post #2 of 3 Old 11-05-2014, 06:02 AM
Levi_Cope's Avatar
try to swap the plug around 180 degrees. some of them are polarity sensitive
Levi_Cope is offline
post #3 of 3 Old 11-08-2014, 05:58 AM Thread Starter
Tried that but the light will only work one way. If you turn it 180 the light won't work at all. I wish there was just a simple fuse to replace? 2013s are so picky! It's driving me crazy! Recon knows nothing about this and they are helpless.
Jk826 is offline
