12v accessory outlet inop - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 11-03-2014, 01:45 PM Thread Starter
woomdawg's Avatar
So this summer I was airing up with home Depot 12v air compressor. I went into my apartment because it was taking forever and when I came back the compressor was dead and so was the outlet. Yea stupid I know, not sure what I was thinking running that off of the power outlet. the problem is that the fuses are all still good M6,M7 and M36. my cigarette outlet work but my 12v Battery outlet is dead. I checked the wiring behind the panle to see if I melted it and the wiring is good up to where it goes into the harness. Anyone have any ideas?
2007 unlimited X
rough country 4" lift
18" KMC Rockstars
superchips flashpaq
1 ton Offset TRE's with 1.5" X .25" wall DOM tubing Tie Rod
1.5" X .25" wall DOM tubing Draglink with 7/8" hiem's
Adam's Front Driveshaft
woomdawg is offline
post #2 of 3 Old 11-03-2014, 02:15 PM
ronjenx's Avatar
M36 is the fuse for the right hand outlet; the one that is always hot.
It gets power directly from the battery bus, so there is no computer involved.
That leaves only a few possibilities.
Bad fuse. Did you try a new one, even though you believe it to be good?
Bad connection at the back of the socket. I have seen several posts where that was the problem.
Bad connection at a splice somewhere along the wire.
Broken wire, hidden by the insulation.
ronjenx is offline
post #3 of 3 Old 11-03-2014, 02:29 PM Thread Starter
woomdawg's Avatar
I checked the plug on the back of the socket and there is no power to the connector.
woomdawg is offline
