HELP!! Codes U1417 and C1020 - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 01-30-2010, 03:20 PM Thread Starter
The Joker's Avatar
I have these 2 codes. I replaced the left rear wheel speed sensor, but it had no effect. any ideas???
The Joker is offline
post #2 of 12 Old 01-30-2010, 03:36 PM
u1417:
VEHICLE SPEED SENSOR FAULT ACTIVE IN ANTI-LOCK BRAKE MODULE
CAN C BUS CIRCUIT SHORTED
CAN C BUS CIRCUIT OPEN
ABS MODULE
PCM
lemme search on 2nd one a little,
savage is offline
post #3 of 12 Old 01-30-2010, 03:40 PM
2nd is CAN communication fault.
seems like #2 & or #3 from my previous post...
anything pinched anywhere under there?
savage is offline
post #4 of 12 Old 01-30-2010, 04:37 PM Thread Starter
The Joker's Avatar
I haven't found anything pinched yet. I'll keep checking tomorrow.
post #5 of 12 Old 01-30-2010, 06:03 PM
Check the connector to make sure it isn't packed with mud... Check the tone ring where the speed sensor sits.. It might be packed with mud or water... Just guessing here..
Vote - Bacon for 2012!!!
benmar2000 is offline
post #6 of 12 Old 01-30-2010, 07:16 PM Thread Starter
The Joker's Avatar
With a quote like that, you know me well!
The connector is fine, but I'll check the tone ring as well.
post #7 of 12 Old 01-30-2010, 08:42 PM
Especially after watching the video of you getting winched at DP..
post #8 of 12 Old 01-31-2010, 09:31 AM
tkob1060's Avatar
yep clean off the sensor where it goes into the housing, my right front was throwing code and locking up brake until I cleaned it off, not sure why dirt on top of it affected it but it did.
tkob1060 is offline
post #9 of 12 Old 01-31-2010, 11:25 AM Thread Starter
The Joker's Avatar
I replaced the sensor. do you think it might be that there is mud inside?
post #10 of 12 Old 01-31-2010, 11:58 AM
That is what I am thinking..
post #11 of 12 Old 01-31-2010, 12:58 PM Thread Starter
The Joker's Avatar
Crap. I have to pull mt wheel spacer off to get to it. guess it will have to wait till next Saturday. replacing the heater core in the Blazer today. It's a pain to get to.
post #12 of 12 Old 07-30-2010, 09:45 AM
Did you ever get this figured out? I have these same two codes and can't seem to get it fixed.
Moretorque06 is offline
