fog light to off road light - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 10-25-2014, 10:12 AM Thread Starter
I just installed a smittybilt front bumper and it has no place for the factory fog lights. If I install some off road lights can I wire them in to the factory harness and use the existing switch?
JoshandChai is offline
post #2 of 5 Old 10-25-2014, 10:38 AM
Guruman's Avatar
yes, and no.
If the replacements are the same or less wattage, then yes. (I replaced mine with Ridgid D2 Duallies)
However, without using a programmer to change the settings, they will only work with the low-beams, the opposite of what I expect you intended.
The Superchips, and I think the AEV Procal can change this for you.
I wish I could set it up so that they only came on with the high beams, but alas that does not seem to be an option.
_
Guruman is offline
post #3 of 5 Old 10-25-2014, 11:12 AM
As said above ,yes and no . I use the factory fog lite switch to switch relays for my extra lighting , fused direct from the battery terminals . When stalk switch energizes all relays energize , then switch each set of lite's has it's own switch for ease of selection . Easy Peasy.....regards k
slick pickel is offline
post #4 of 5 Old 10-25-2014, 11:17 AM Thread Starter
Thanks for the help. I would prefer to have them come on when I want them on. Will decide how to proceed.
post #5 of 5 Old 10-28-2014, 02:42 AM
I have superchips. How do you program for the driving lights to come on with high Beams?
Thanks.
JeepUpKeep37s is offline
