Getting wires into the cabin.. - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 01-26-2010, 11:56 PM Thread Starter
hambone303's Avatar
I have installed several switches for offroad lights and the rear locker mod to the left of the steering wheel, on the panel beneath the vent. I came into the cab with wiring through the small hole on the drivers side firewall, the one that is filled with spray type foam...Anyway, I am running my coax from the antenna, and the coax end will not fit through that hole with the other wires already there. Where else can I get a coax cable into the Jeep without sacrificing a seal or weather boot? I ran through the cable through the framerail on the driver side, and planned on going through that foam filled hole but it is not going to work. Is there another place close by or do I need to re route the wire completely? Thanks
2007 Rubicon Unlimited 4D Silver, 4" Superlift
35x12.50x15 BFG KM2s, Summit Racing 15" wheels
Smittybilt XRC front bumper with XRC8 Syn
96 XJ, 8"lift, 36" Swampers, 8.8 detroit rear, lots of other mods
hambone303 is offline
post #2 of 6 Old 01-27-2010, 01:31 AM
chasinternet's Avatar
Isn't your antenna installed on the rear on the vehicle?
This is how I did it:
Remove the two tail light screws toward the center of the vehicle, tail light assembly comes off, and you'll see how the wire harness goes inside. The foam panel in the bottom of the space lifts up, you can also see it from under the vehicle - bring the coax through there. I cable tied the coax to the electrical harness going to the front of the vehicle, the door sill plastic comes up by working those those plastic "christmas tree" plugs out, or if you get lucky and it doesn't snag, just push the coax through.
Clinging to God and my Jeep keys since 11/10/2007
Lifetime membership: BlueRibbon Coalition, United Four Wheel Drive Associations (UFWDA),
California Association of 4WD Clubs (CA4WDC) - Get involved in Land Use or its no use!
chasinternet is offline
post #3 of 6 Old 01-27-2010, 12:53 PM
Another option if your antenna is at the back
I ran my coax in through the tailgate opening. I lifted up the seal in the lower passenger corner and ran the wire through there. Does not affect the sealing of the tailgate at all. I then ran it along the passenger side under the carpet to the passenger side of the dash where I have my Cobra 75 box mounted.
Mark
mshogren is offline
post #4 of 6 Old 01-28-2010, 04:05 AM Thread Starter
hambone303's Avatar
Thanks for the ideas. The tail light opening works great for me, as my antenna mount is inside the tag holder.
post #5 of 6 Old 01-28-2010, 05:58 AM
neoxxis's Avatar
Mark
Yeah, pretty much the same here...
Under the plastic cover, into the big hole, out through the rubber grommet...
No cutting, etc. Just cut an X into the rubber grommet...
neoxxis is offline
post #6 of 6 Old 01-28-2010, 07:15 AM
I was thinking bumper mounts, mine is license plate holder mounted with an internal bracket I made.
The tire carrier is of course the more common placement and that tailgate grommet idea is the way to go. I do that for my back-up camera cable.
