blinker malfunction - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 10-13-2014, 01:33 PM Thread Starter
blinker malfunction
I have a 2007 JKU. When activating the left turn signal the front works, but the rear does not. Also, the right side blinks when the left side is activated. I changed the bulb because the rear brake and blinker on the left side didn't work. That did not fix it. I checked the fuses and they are good. Please help. Thanks.
dawgfan1 is offline
post #2 of 7 Old 10-13-2014, 02:03 PM
JeepnPokey's Avatar
check the grounding wire in the tail lamp...
OIF
JeepnPokey is offline
post #3 of 7 Old 10-13-2014, 02:17 PM Thread Starter
which wire is it? All the wires were plugged in and together when I pulled out the light. I didn't see any loose or free hanging wires.
dawgfan1 is offline
post #4 of 7 Old 10-13-2014, 02:36 PM
Ringer's Avatar
Are you running standard bulbs. The wrong Led bulb can cause some weird issues.
Or you could just be low on fluid.
Name:  ImageUploadedByAG Free1413232600.125037.jpg
Ringer is offline
post #5 of 7 Old 10-14-2014, 08:49 AM Thread Starter
could it be as simple as an LED light causing the issues? I will go buy a standard bulb today and try it. Thanks
dawgfan1 is offline
post #6 of 7 Old 10-14-2014, 12:52 PM
JkO Approved Vendor
Diode Dynamics's Avatar
If you installed LEDs, you'll need to install load resistors
Otherwise, check to make sure the bulb is seated in the housing properly
Nick C.
Diode Dynamics is offline
post #7 of 7 Old 10-14-2014, 01:00 PM
JeepnPokey's Avatar
Attachment 177538
That was my next suggestion... haha
OIF
