rigid back up light won't work - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 09-28-2014, 02:08 PM Thread Starter
searched but could not find answers.
i just want rigid lights in rear bumper to turn on when in reverse. i wired in a relay and i think everything is wired correct.
the problem is i can not get light to turn on with the jumper wire to the relay. when i tap the number 86 from relay to direct power relay clicks and lights turn on but i can't get them to work when taping into harness above driver rear tire. i have used the white with green strip and white with grey strip….they seem to switch in harness to tail light reverse wire.
this is a 2014 jku…
am i using the wrong relay or tapping into the wrong wires? i can't get my test light to work on any wires in the harness. seems like there is power to any of the wires?
ranjeeps14 is offline
post #2 of 8 Old 09-28-2014, 02:57 PM
14Sport's Avatar
Are they LEDs? Shouldn't need a relay for LEDs. They only way to test the reverse wires is to have the Jeep in reverse. You will need a helper for that.
2014 JK Sport, auto, 35x12.5x17, 3.73s.
I jeep therefore I am.
14Sport is offline
post #3 of 8 Old 09-28-2014, 03:49 PM Thread Starter
they are led.
i have put it in reverse…. actually running and just key on and shifter in reverse and they still won't work.
post #4 of 8 Old 09-28-2014, 03:50 PM Thread Starter
should i just splice them into the two wires going into the bulb? red to white green one and black to black
post #5 of 8 Old 09-28-2014, 03:58 PM
14Sport's Avatar
That's what I did. I can't remember which white but I believe it was the outside one on the connector. I remember checking one and it didn't work so I switched it. It's raining now but if you need me to pull the tail light and take a pic I would be more than happy too. Once the rain stops.
14Sport is offline
post #6 of 8 Old 09-28-2014, 05:04 PM Thread Starter
done and they work. i just spliced them into the reverse bulb wires. black to black and white green stripe to red.
hope it lasts and dosnt mess things. up…. for some odd reason the rely wouldn't work. but i am no electrician
post #7 of 8 Old 09-28-2014, 05:16 PM
14Sport's Avatar
Awesome. Mine have been working that way for a year so I think you're good.
14Sport is offline
post #8 of 8 Old 09-29-2014, 04:27 AM
14Sport's Avatar
Well if the relay was wired correctly it should have worked. On a SPST relay, pins 30 and 87 are the feed to the accessory. Bring power in to the relay through pin 30 and when the relayed is triggered, it internally connects pin 30 to pin 87 thus allowing the power to come out pin 87 and turn on the accessory.
Pins 85 and 86 are the trigger circuit. When you run power through those pins it makes the pin 30 to 87 connection. So pin 86 goes to ground and pin 85 could be fed from the reverse light positive wire.
14Sport is offline
