Flick Flick - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 09-17-2014, 05:43 AM Thread Starter
Flick Flick
Does anyone have any experience with ET's Anti-Flicker kits? I'm currently running them with Amazon LED headlights and I still have a flicker problem. I'm leaning more towards the problems being with the Flicker kits mainly because of the construction of them. The connectors are cheap which caused a lot of problems during installation...
http://www.extremeterrain.com/lifeti...-jk-h13rh.html
JKUWILLY is offline
post #2 of 7 Old 09-17-2014, 11:25 AM
XTJake's Avatar
That part is made by Lifetime LED which is a company known for quality. I think they'll work well for you and I wouldn't expect any issues with the connectors. If you'd like to try a set, I can send some out to you free of charge if you'll do an honest review of the part on the forum here and also on our site. Pm me with your info if you're interested!
-Ryan
Jake R. |
Off-Road Outfitters
Toll Free: 800-988-4605 | Mon-Fri 10AM-6PM EST
Free Shipping on Orders Over $75!
PM me for our JKOwners Discount Code (must have 25 posts) or Price-Matching!
XTJake is offline
post #3 of 7 Old 09-17-2014, 12:48 PM
Guruman's Avatar
Our JK's really need both a resistor (to make the bulb check happy) AND a capacitor (to bridge the gaps in the PWM pulses and eliminate the flicker)
Looking at the part, I only see the resistor.
_
Guruman is online now
post #4 of 7 Old 09-18-2014, 09:30 AM
XTJake's Avatar
I agree with you. I hear that this part fixes the flickering issue but I don't see a cap in the pictures either. I'm going to look into it further and see what they have to say. I'll let you know what I find!
-Ryan
Jake R. |
Off-Road Outfitters
XTJake is offline
post #5 of 7 Old 09-18-2014, 10:36 AM
XTJake's Avatar
According to Lifetime LED only a resistor is needed to keep the lights from flashing. The flickering is caused by the CANBUS system thinking you have a blown bulb because of the lack of resistance given by the LED. The system "checks" to see if the circuit has resistance 10 times/second which causes the flicker. The resistor tells the CANBUS that they bulbs are intact and there is no flickering. Let me know if that wasn't clear!
Bottom line is that a cap isn't needed to stop the flickering, just a resistor.
-Ryan
Jake R. |
Off-Road Outfitters
XTJake is offline
post #6 of 7 Old 09-18-2014, 01:17 PM
Guruman's Avatar
Well, I hate to break it to you, but that is wrong. A resistor will do nothing to fill in the gaps from the pulse width modulation that feeds our lights. Basically the power to the headlights is switched off and on rapidly (why... I do not know.) it does this all the time, not just when "checking" the bulb.
With a heated filament the "off"cycle is not sufficiently long enough to allow the filament to cool down, and it remains hot and bright. LEDs do not rely on heat to emit light, so when the pulse is in the "off" cycle the LEDs go out completely, causing visible flicker. The resistor does absolutely nothing to solve that problem, all it does is add a load that the CANBUS "sees" during the "on" cycle, fooling into thinking a 1 watt LED is really a 35watt incandecent bulb.
Wheras, capacitor will store a small amount of electricity, feeding it back into the circuit during the "off" phase of the cycle, keeping the LEDs lit. Without it, just as the OP has stated, you'll have flicker.
_
post #7 of 7 Old 09-19-2014, 08:19 AM
XTJake's Avatar
I understand the purpose of a resistor or capacitor in the circuit. I don't have a strong understanding of how the CANBUS works or why the lights flicker. The explanation from Lifetime about "checking" for a bulb made sense to me but in light of your explanation it's cloudy again. I'm going to get back in touch with them and see what they say.
On a side note, they sell a lot of these harness and they work to eliminate the flickering. We just have to figure out how and why they work!
Edit: Upon further research, the PWM that is done by the CANBUS system is designed to increase bulb life, which supports your statement that it happens all the time. The Truck-Lite anti-flicker harness includes a cap to work as you've described. I'm still waiting on a response from Lifetime to explain why their harnesses don't include one and why they still work.
Edit 2: Lifetime stopped responding to my questions about why their harness works without a capacitor. They only stated that the harness "work quite well". My only thought is that the Lifetime LED bulbs that this harness is designed to work with include their own capacitor. That would mean the harness only needs a resistor to trick the system into thinking a higher draw bulb is present. That may mean that Lifetime is correct in that their resistor harness is designed to stop flickering from bulb "checking" because the LED bulbs they designed the harness to work with already have a capacitor in them to solve the PWM flicker. If this is the case my initial suggestion to use this harness with the LED headlights would be incorrect, unless the bulbs have their own capacitor built in. Sorry for the confusion!
-Ryan
Jake R. |
Off-Road Outfitters
XTJake is offline
