Automatic headlights? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 09-10-2014, 06:09 AM Thread Starter
CeeeJaySeven+JKU's Avatar
Has anyone ever tried to install the automatic headlights in a 2014 sport? They come standard or as options in the Sahara and Rubicon. Is it just a switch? Or is in a whole integrated harness which the sports don't have installed? (Kinda like remote start.)
Big B.
2011 4Dr Unlimited... Rubi springs & shocks, Rubi tires, JKS QD's, CoverKing Seat covers, Rugged Ridge trail doors, A.C.E. stubby bumper, A.C.E. Rock Rails, A.C.E. Hi-lift jack mounts, Superwinch LP8500.
1983 CJ7 LAREDO, AMC 360, 5" lift, 33's
CeeeJaySeven+JKU is offline
post #2 of 8 Old 09-10-2014, 07:08 AM
nlgrav182's Avatar
Don't know and never tried, but in my '05 WK the fog lights were pre-wired, it just need the housings, the stalk, and programming.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #3 of 8 Old 09-10-2014, 07:32 AM
Victim Of Pain's Avatar
Procal allows you to program daytime running lights, I have my fogs running now and you can pick and choose what lights you use. It's a 2008 though, not sure if the new ones do the same. Maybe someone else can chime in.
Victim Of Pain is offline
post #4 of 8 Old 09-10-2014, 11:55 PM
ATX_JKU's Avatar
Pro cal works on the 2014s too. Choice of headlights, fog lights or side lights once in gear I believe.
2014 JKU Sport White, Auto, 3.73s
3'' Trailmaster with 3/4'' spacers
35'' KM2 on 15'' Baja 8s
15'' Earthquake subs with Boston Acoustic upgrade
AEV Procal
Angry Off-Road Handles
Custom Stubby Bumper w/Stinger
2007 Suburban 4x4 LTZ
1995 F-350 4x4 (Smoking fast)
1999 Cherokee 4x4 Rough Country Lift on Rubi take offs
1996 Cherokee 4x4 Skyjacker lift on 32s Locked front and rear
ATX_JKU is offline
post #5 of 8 Old 09-11-2014, 06:28 AM
offroad's Avatar
I may be wrong, but I think the op is asking about headlights that turn on automatically when it gets dark, not daytime running lights.
offroad is offline
post #6 of 8 Old 09-11-2014, 08:37 AM
Pretty sure that he is wanting to know about the lights that turn on automatically depending on outside brightness.
I haven't seen it added--however with the way the JKs are made (all are modular--you really can, albeit at great expense, add anything you want to any model from another trim level).
As an owner of a 14 with auto lights (and a ram owner with auto lights (same setup) what you will need:
You are going to need a new stalk for the lights (there IS a marker for the AUTO on/off), you will need the sensor (sits in the middle of the dash up front). and as both of these will need to talk to the can-bus system, you are going to need a re-program.
The three differences that I am unsure about at the moment. 1. If the harness is the same and these simply clip into it, or 2) is there a different harness altogether. 3) is the dash the same. I can't see the dash being different, however it might be to accommodate the sensor.
RHenthorn is offline
post #7 of 8 Old 09-11-2014, 09:05 AM
You could just use a photo sensor and relays to power the headlights from a switched power source.....major hack but should work....or just twist the stalk when it gets dark
KCJK is offline
post #8 of 8 Old 09-11-2014, 12:43 PM
soonerfan85's Avatar
What KCJK said.
I'd gladly give up my automatic headlight feature for headlights that actually illuminate the road.
soonerfan85 is offline
