routing coax and cb related questions - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 01-12-2010, 07:45 PM Thread Starter
TheBeatenPath's Avatar
im gonna run my coax when i get the chan and i was wondering the best route.im mounting it by the drivers knee and i have the coax routed throught the tail gate already.
im wondering if i should follow the stock wire from the right rear panel area then turning it to the left in front of the rear bench and then turning right in between the center console and drivers seat to the cb. does it matter the routing? if it gets stepped on will it mess up? if the carpets out do you just have the wire visible and running to the radio?
its a 2dr
how would you guys do it?
on another note is the jk positive or negate based grounding system?
it says it can run of any 12 volt source. can i splice the power cord into a phone charger thing so i can plug it in and out?
is there a way to be able to take the cb out and put it back in without having to tune it everytime?
can i take teh antenna on and off without having to tune it?
TheBeatenPath is offline
post #2 of 11 Old 01-12-2010, 07:50 PM
Broncojohn's Avatar
its a 2dr
Route it any way you want keeping it away from any amplified speaker wires.
The Jeep is a Negative ground system.
Once the system is set you can remove the antenna without tuning as long as you dont mess with the tuner. They do sell quick disconnects for antennas but you will have to watch it, it makes it very easy for them to walk.
Broncojohn is offline
post #3 of 11 Old 01-12-2010, 10:22 PM
RIP Brad
abendx's Avatar
I was talking to John from sPOD and he suggested running wires that are used in the rear through the frame rails. It was too late fro me as I had already ran several electrical wires and cb coax along the right side with the other factory wires, but it was a GOOD idea. I think when ever it is that I decide to spray some bed liner in, I will redo the wiring in the rear like he suggested.
abendx is offline
post #4 of 11 Old 01-12-2010, 10:56 PM
SONIC's Avatar
I'd run the coax along the passenger side.
You can easily tuck it under the carpet and the trim and it wont be visible at all.
Dont step on it.
Keep it away from any power wires (amp, etc)
You can remove it without tuning it again
you can also cut all the zip ties and put it into the factory wire loom if you want. I have mine tucked in real well and have a herculined tub, you cant tell its there at all.
-Doc Holiday
SONIC is offline
post #5 of 11 Old 01-13-2010, 02:26 AM
Gavitron's Avatar
I ran mine up the roll bars, under the padding. I don't know if the 2drs have the same rear crossbar as the 4dr, but if it does, you've got a clean run straight to the A pillar, where you then drop down into the dash.
Don't run your CB off the Cigarette lighter if you can help it - Straight from the battery to a fuse, across the engine bay to the driver's side, through the firewall, into a NOISE FILTER, and then to the radio is what I'd do, given your chosen location. maybe it's just my radio being too sensitive, but the white noise from the Alternator/CanBus was terrible on mine without a decent power supply filter.
Gavitron is offline
post #6 of 11 Old 01-13-2010, 03:54 AM
scottrock's Avatar
X2 on the + & - straight to battery with a fuse on the +. If you plug it into the cigarette lighter you'll more than likely pick up noise from the alternator.
As for the coax, I ran mine under the console, under the front of the passenger seat (just behind the front seat brackets & stuffed it in the factory loom) into the factory plastic that runs near the door sill, around the B pillar and again into the factory wire loom all the way back to the tailgate. Definitely keep it out of areas where it can get stepped on or abraided. Unless you just like to replace coax.
scottrock is offline
post #7 of 11 Old 01-13-2010, 01:59 PM Thread Starter
alright thanks for all the help guys we like zipties so we will probably go that route.
so you just have the wires running directly to the battery leads?
post #8 of 11 Old 01-13-2010, 03:37 PM
Scooter Scott's Avatar
I have a main 8 gauge wire coming into my cab that is fused which is what I run mine off of. I have since tied that into my fogs as well. I figured that an 8 gauge wire could handle all of that so I'm not too worried about it
Scooter Scott is offline
post #9 of 11 Old 01-14-2010, 12:22 AM
Gavitron's Avatar
if by direct, you mean "Ring terminals crimped & soldered, with heatshrink liberally applied," then yes, direct to the battery terminals.
This is just a pic of my sPod install, but you can see where the leads connect to the battery terminals. all my radios take power from the same terminals.
If you really need it, I can take a pic of the current mess tomorrow.
Gavitron is offline
post #10 of 11 Old 01-15-2010, 11:15 AM Thread Starter
thsnkd for the pic thats what i nneded to see that looks good to me.
got all my carpet out and ran the coax i didnt ziptie it in yet i might not need too its in pretty good and as soon as it hits the passenger side pillar you dont even see it until you get to the cb bracket its the pefect distance.
two door needs 20 feet if you wanna do it out of the way and comfortably to the driver side knee.
we are still thinking if we wanna put the carpet back in or not i personally like it but my parents gotta like it too
post #11 of 11 Old 01-16-2010, 07:02 PM Thread Starter
got my cb grounded hooked to the battery grounded my antenna and put in the rear carpet. im gonna tune it monday
