TIPM shit the bed - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 01-12-2010, 06:06 PM Thread Starter
Dr.Dirty's Avatar
Feedback: 21 reviews
TIPM shit the bed
Well the Jeep is dead in her track i guess the TIPM doesnt want to work any more.
I pulled the fuel pump out and tested it and it works fine
Not having a warranty sucks sometimes
www.jeepasylum.com
Dr.Dirty is offline
post #2 of 12 Old 01-12-2010, 06:09 PM
paramaniac's Avatar
I'm on my 3rd TIPM.
Not quite sure what the actual cost is, I do know they charged only 1 hour of labor to replace it, so I'm guessing it's pretty easy
paramaniac is offline
post #3 of 12 Old 01-12-2010, 06:24 PM
SFCCotton's Avatar
That sux! But your Guardian Angel has your back!
SFCCotton is offline
post #4 of 12 Old 01-12-2010, 11:31 PM
sPOD-guy's Avatar
Feedback: 12 reviews
Well, first check your relays within the TIPM (Totally Integrated Power Module) to make sure none of them have failed first.
Does the Jeep crank over and not start? Or is it just plain dead? What lead you to believe the fuel pump is at fault?
I think there was a Safety Recall G25 Reprogram TIPM – Engine Stalling.
Are you tapping any external power from it for electrical accessories?
-John the sPOD guy
switches jeeps panels jk-forum carling contura led switch windshield
sPOD-guy is offline
post #5 of 12 Old 01-13-2010, 06:35 AM Thread Starter
Dr.Dirty's Avatar
I checked all the relays a few times , the jeep cranks but wont start, well there is no fuel pump realy only a fuse in the TIPM and the fuse was good so i replaced the fuse any way and still no solution. So i decided to drop the tank to check the fuel pump hoping it was the fuel pump and I bench tested the fuel pump and it worked fine, so for giggles i put the pump back on the tank and hooked the fuel lines back up and then ran a seprate power to the fuel pump and the Jeep fired right up. so then i traced the whole harness looking for any type of damage and it was all good.
i belive the recall G25 was for rigs built before JAN 07 but i havent had any luck finding the recall
www.jeepasylum.com
Dr.Dirty is offline
post #6 of 12 Old 01-13-2010, 07:21 AM
If it's not under warranty make your own relay harness for the fuel pump. It'll work just fine, anti-theft device too
post #7 of 12 Old 07-08-2010, 04:12 PM
fnc
fnc's Avatar
Did you end up replacing the TIPM yourself? I have to replace mine but the stealership wants $510.00 to do it (no warranty). I have a connection and can get a new TIPM for $165.00 plus shipping. The work itself is easy and it should only take about 10 minutes to swap the TIPM out but I am wondering if I will need to have the thing flashed/re-flashed after doing it.
I can taste your meat from all the way up here.
fnc is offline
post #8 of 12 Old 04-22-2011, 10:07 PM
JKrazed's Avatar
Feedback: 13 reviews
Maybe he was thinking TPMS??
PROUD to be an
JKrazed is offline
post #9 of 12 Old 04-23-2011, 05:18 AM
Yep, long night!
It should need to be reflashed/coded to the vehicle. I'd imagine you can just get the dealer to do just that if you wanted them to. They did have a programming time allotted when they replaced mine under warranty.
I have a friend I used to work with in Las Vegas that has a friend that works at Jeep (or did) that always did the work on mine. I could probably get the "low-down" on it.
post #10 of 12 Old 04-23-2011, 06:41 AM Thread Starter
Dr.Dirty's Avatar
When I get home I can look in the Service repair manual. I remeber reading that it doesnt need to be programmed. There is a procedure to get the PCM to send the TIPM the info it needs. I wish i would have had the manuals before wasting money paying jeep to do nothing.
Dr.Dirty is offline
post #11 of 12 Old 04-23-2011, 08:11 AM
owtdorz's Avatar
Here are two things from Chrysler:
INSTALLATION
CAUTION: The original Cabin Compartment Node (CCN) and Powertrain Control Module (PCM) must be installed and functioning properly prior to powering up the new Totally Integrated Power Module (TIPM). The TIPM receives vehicle configuration data from the CCN and Vehicle Identification Number (VIN) information from the PCM. If configuration information becomes lost or corrupted, the data can be obtained from DealerCONNECT
NOTE: Left hand drive gasoline engine shown, left hand drive diesel similar. Right hand drive gasoline and diesel similar with the battery and related components packaged on the left side of the engine compartment.
1. Position the TIPM (1) into the engine compartment.
2. Connect each of the seven TIPM wire harness connectors.
3. Position the TIPM (1) onto the mounting bracket (4) and push down until the mounting clips are fully seated.
4. Position the TIPM positive cable (4) onto the mounting stud and install the retaining nut (2). Tighten the nut to 9 - 11 N·m (80 - 100 in. lbs.).
5. Open the TIPM cover (1) and fully seat the Airbag fuse holder (two fuses in one yellow carrier) and the Ignition Off Draw (IOD) fuse.
6. Connect the battery negative cable.
7. Close the hood.
8. Insert the ignition key and turn it to the “RUN” position and wait twelve seconds. The TIPM will collect the necessary vehicle configuration and VIN data from the CCN and PCM at this time. After twelve seconds turn the ignition key to the “OFF” position and then back to the “ON” position and verify proper vehicle systems operation.
and
PROGRAMMING
1. Install a battery charger.
2. Verify that the charging rate provides approximately 13.5 volts.
NOTE: Do not allow the charger to time out during the reconfiguration process. Set the battery charger timer (if so equipped) to continuous charge.
3. Connect the CH9410 StarSCAN ethernet cable to the StarSCAN and the dealer's network drop.
4. Connect the CH9404 StarSCAN vehicle cable to the StarSCAN and the vehicle.
5. Place the Ignition in the “RUN” position, then Power “ON” the StarSCAN.
6. Select “ECU View”.
7. Select “TIPMCGW” or "FCMCGW".
8. Select “MISC”.
9. Select “Restore Vehicle Configuration”.
10. Follow prompts on StarSCAN to complete the reconfigure procedure.
11. Once complete, Wait one minute and turn the ignition key to the “OFF” position.
12. Remove the StarSCAN unit, cable and charger from the vehicle.
13. Verify proper operation.
'09 4dr Rubi Detonator Yellow
3.5 Mid arm Rock Krawler
Finally 5.13s
owtdorz is offline
post #12 of 12 Old 04-23-2011, 08:33 AM Thread Starter
Dr.Dirty's Avatar
INSTALLATION
7. Close the hood.
and
PROGRAMMING
8. Select “MISC”.
Thank you. So as long as your not having PCM issues you will be fine.
Dr.Dirty is offline
