TIPM and Heated Seats - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 08-28-2014, 08:18 PM Thread Starter
So, I've got a set of Warmseats waterproof seat warmers on the way.
The instructions direct you to wire the supply for them into the cigarette lighter circuit, and while I know that will work, I'm a little anal-retentive about my electrical work. (Occupational hazard)
So, for those of you more familiar with the inner workings of a TIPM, I have a question.
I was looking at running my power directly from the TIPM by adding a wire to the harness at plug C6, pin 14. (Found the data on a couple of threads, but planning to continuity check it since the 2011s can be screwy.)
Will the TIPM allow the current draw through that path, even though I don't have the factory heated seats, or am I thinking that the TIPM is smarter than it actually is?
Thanks.
Haggis_Forever is offline
post #2 of 9 Old 08-28-2014, 08:48 PM
ronjenx's Avatar
If you put a 20 amp fuse in position M8, and a minimum 16 awg wire with appropriate pin connector into C6, pin 14, the new wire will be hot when the ignition key in in the RUN position.
Here is a picture of some other fuse locations with connector and pin numbers.
Here is another way to do it. https://www.jkowners.com/forum/showthread.php?t=57703
Not as clean as going under the TIPM, but still better than tapping onto the cig lighter socket.
ronjenx is offline
post #3 of 9 Old 08-28-2014, 11:31 PM Thread Starter
That's what I was hoping for. I just wasn't sure how much computing took place in the TIPM.
Thanks for the writeups on the TIPM, by the way. They've been extremely helpful. Have you had any luck sourcing the terminal lugs that go in the plugs to the TIPM? I've been looking, but I can only find them in lots of 2000, which may be a little more than I need...
post #4 of 9 Old 08-30-2014, 04:07 PM
I didn't think there was a problem with tapping into the AUX cig lighter circuit. It is keyed, and certainly rated for more than enough amperage to run seat heaters. Seems to work fine.
I think the Warmseats inst actually suggest that option.
wrangled is offline
post #5 of 9 Old 08-30-2014, 06:17 PM
ronjenx's Avatar
A soldered connection is fine. It's the squeeze taps that are less than desirable.
Better to have the seats on a "RUN" circuit rather than an "ACC" circuit.
ronjenx is offline
post #6 of 9 Old 09-01-2014, 06:16 AM Thread Starter
Yeah, those squeeze taps make me cringe.
Running the wires from the TIPM will be more of a pain, but I think I'll have a little more peace of mind knowing that there's no chance of overloading the lighter circuit.
post #7 of 9 Old 09-01-2014, 06:27 AM
ronjenx's Avatar
I found the lugs from a Jeep in a junk yard. Any late model Jeep vehicle should have the lugs you need.
Be careful, though. Each connector can have several different types of wire lugs in it.
ronjenx is offline
post #8 of 9 Old 09-02-2014, 10:12 AM
CUNT
Matti's Avatar
Location: The Land of the Polite, Where shits covered in Ice.
Wheres the pinout diagram for those connectors?
Originally Posted by DMadole View Post
As previously mentioned, the key step in this process is saturating those whores in piss.
Originally Posted by maunder View Post
I just gotta say.. When you're being butt hurt by your fudge packer minions.. how do you decide which one gets to pull the pony tail n who's left to cup the balls.. If there is any..
Matti is offline
post #9 of 9 Old 09-03-2014, 03:17 PM Thread Starter
I haven't found a pinout diagram, but Ronjenx has some TIPM writeups that provide some information. That's where I drew my data from.
