Running wire for above windsheild 50" light bar - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 08-28-2014, 01:16 PM Thread Starter
upalms's Avatar
How are you guys running the wires for the light bars, I have a Daystar lower panel, may change to the pillar version, but how are you getting the wire inside, I saw one set up the guy was just closing the door on it? There has to be another way, right?
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
Synergy Front Suspension
Artec Front JK Armor
5:13's
Tom Woods Drive Shafts
Hi-Lift & Much More
2000 TJ
6" lift
37 TOYO MT's on Worx Rims
$hitty Built bumpers
Air Raid
Corbeau Baja RS seats
upalms is offline
post #2 of 4 Old 08-28-2014, 01:44 PM
I run mine down the passenger side mount then under the cowl with the four screws in it. When you open your hood, use a flashlight and look back right next to the fender you will see a hole on each side with foam in it. Take a coat hangar or something and fish your wires through there. You will have to take off the cover on the end of the dash to access it as well.
if you plan on running a cage in the future run whatever wires you ever think you are going to need now. Removing the cage just to run wires is a PITA.
post #3 of 4 Old 08-28-2014, 08:54 PM Thread Starter
upalms's Avatar
Very Cool, thank you, great pic, works for me
What these boards are all about
Todd
2007 Unlimited
Cree Light Bar
7.5 Long Arm Lift
5:13's
Hi-Lift & Much More
2000 TJ
6" lift
Air Raid
upalms is offline
post #4 of 4 Old 08-29-2014, 12:30 AM
UnlimiDozer's Avatar
You can do the same thing on the driver side, and with the PSC cage, it's still accessible after the cage install.
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
