Aftermarket seat heaters into factory switched - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 08-09-2014, 11:18 PM Thread Starter
Cnd.Skippy's Avatar
So I recently just installed some prp daily driver seats into my jk which had seat heaters originally. My question is has any successfully wired in the aftermarket elements to work with the stock switches. I tried cutting the new connectors off the new heaters and soldering then to the factory harness but when ever I try and turn the heater on the switch lights up for about three seconds then turns off.
Any help would be greatly appreciated
2012 JKU Sahara - Current SmittyBilt XRC Front and rear Bumper W/8,000lb X20 Winch, 40x15.5x20 Geolander MT, Front/Rear D44 Axles w(EVO Sleeves/Gussets, RK trusses, DynaTrac Diff Covers - Front/Rear & Ball Joints, Chromoly Front Axle Shafts, 5.13 Gears ,lockers), EVO Skid Plates, Poison Spider Fenders and Brawler Knocker Sliders, 5.5 RockKrawler X Factor LA, Fox shocks, 1310 front DS, 1350 rear DS, Red and White Rock Lights
Cnd.Skippy is offline
post #2 of 2 Old 08-10-2014, 12:47 AM
Jonboy's Avatar
I haven't done this but if you have the wires running from the stock switches you could try using them to trip a relay to power the new seat heaters. Maybe they are cutting off b/c there's a different power draw on the new ones or something.
Jonboy is offline
