CB ISSUES - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 08-08-2014, 07:49 AM Thread Starter
bass5money's Avatar
CB ISSUES
SO I bought and installed a cobra 75 cb with firestick antenna and quick disconnect. even with squelch all the way down a get a choo choo choo choo noise. Took it to TTT truck stock cb guy and he says the install is just like he would have done and looks good. He tested the receiver and cb and they are fine. he said possibly something else grounded could be causing it.
I removed everything electronic that I anstalled from battery and still does it. Removed the 2 sets of grounded wire harnesses from inside passenger wall and still does it. no key in care nothing turned on it still does it.
I remove the entenna and it gets very quiet re-install it and it get loud again.
I am stumped and cb guy is stumped, he said if I figure it out call him and tell him what it was..
Has anyone had a similar issue? Oh and he also said the more ground added makes it worse..
2014 jk oscar mike edition. Manual. 3.5" Rubicon super flex suspension lift. 35" AT tires 17" method rims. Body armor doors. Smitty built MOD front bumper. Smittybilt 9500 lb winch, ARB twin compressor, Spod with gauge, D2 LED's.
bass5money is offline
post #2 of 18 Old 08-08-2014, 09:58 AM
2Door's Avatar
Try removing that disconnect.
The problem lies in your coax cable, back to the antenna. Start at the radio box and work back. If you determine the cable to be good, which it probably is because you mentioned that you removed the antenna and it was better, antenna mount and grounding. Also, check how you installed the Firestik antenna onto the stud (they have a certain order for washers and stuff) cause it might be grounding out.
Finally, did you tune it? Mine is tuned to 1.5 (I have the same setup) and it has been working really well.
2011 Sahara Tan 2dr Rubicon
2Door is offline
post #3 of 18 Old 08-08-2014, 10:12 AM
funfred's Avatar
Are you near any kind of radar array like an airport or doppler weather station?
funfred is offline
post #4 of 18 Old 08-09-2014, 10:27 PM Thread Starter
bass5money's Avatar
Ran new cable same issue. Checked ground with meter from antenna ground to chassis that's good. Truck stop tested cb that's good. Tried another antenna still does it. Tried running new power and ground from transmitter outside jeep to battery same thing. Tried putting a fuse on ground line again same thing.
Nothing is turned on no key in jeep nothing on still does it. I grab top of antenna noise stops. Pull ground from battery went to chassis still problem. Pulled ground again not connected to anything and the cb still has power..weird..
Maybe just a bad transmitter? Tried to buy another today went to 5 places nobody has one. Tried getting ahold of righchannel.com were I got it at..they have no phone number..emailed them no reply yet.
I am so frustrated.
post #5 of 18 Old 08-09-2014, 10:29 PM Thread Starter
bass5money's Avatar
Not near any airport it does it anywhere.
post #6 of 18 Old 08-09-2014, 10:46 PM
Probably Stuck on my Diff
11jeeperdrummer's Avatar
Hey man, careful with TTT, those guys really arent helpful. I went there when everytime I keyed up, my windshield wipers would go on.. He was telling my how my radio must be pushing more power than normal.. turns out it was a bad antenna mount ground. I would suggest you get a multimeter and check the continuity between the cable and the antenna mount and the firestik adapter.
If you grab the top the of antenna and it stops, that sounds to me like a bad ground. (either the antenna or the mount).
More Cowbell
11jeeperdrummer is offline
post #7 of 18 Old 08-10-2014, 10:50 PM
UnlimiDozer's Avatar
Originally Posted by 2Door View Post
. . . check how you installed the Firestik antenna onto the stud (they have a certain order for washers and stuff) cause it might be grounding out.
Go to this link and compare to your installation. It could be that you have the fire ring upside down. If so, you would be trying to use your Jeep as an antenna and your antenna as a ground plane. No so bueno.
http://www.firestik.com/Tech_Docs/mkfr-instl_nohook.htm
My Build Thread:
I'm the NRA
JOIN HERE:
UnlimiDozer is offline
post #8 of 18 Old 08-10-2014, 10:55 PM
2Door's Avatar
Before I bought mine, I heard of guys having issues with the grounding of the fire ring cables. So, I opted out and just bought a regular coax. If it is stopping when you grab the top, could it be a tuning issue?
2Door is offline
post #9 of 18 Old 08-11-2014, 04:30 AM
bgall's Avatar
Definitely sounds like antenna grounding. No pics makes it hard for us to help. Are you using just the mount for ground or did you run an extra ground? How did you test ground to chassis? I always run an extra split ring ground from the antenna to the body. Just make sure you do NOT touch the antenna core when you run one. There should be zero continuity between the lower mount and antenna on top.
I have jeeps. I do shit to them.
bgall is offline
post #10 of 18 Old 08-11-2014, 06:32 AM Thread Starter
bass5money's Avatar
I don't have a fire rind set up. I have a fire stick antenna and coax cable. The lipped part of the washer is facing down.
post #11 of 18 Old 08-11-2014, 06:41 AM Thread Starter
bass5money's Avatar
I'll try to make a vid..
post #12 of 18 Old 08-11-2014, 08:28 PM
My mistake. Guess I just assumed . . .
My Build Thread:
I'm the NRA
JOIN HERE:
post #13 of 18 Old 08-12-2014, 12:10 AM
BumpInTheRoad's Avatar
Not sure if I'm envisioning this right, but the mounting sequence should be, from top-to-bottom:
Antenna
Antenna Base
Lock Washer
Flat Washer
Nylon Insulating washer
Mount
Coax Connector
I'm a JKO Reject
BumpInTheRoad is offline
post #14 of 18 Old 08-12-2014, 06:24 AM Thread Starter
bass5money's Avatar
Yes it's just like that ^^^^^^ minus the lock washer and split ring . Plastic washer with flanged side down.
post #15 of 18 Old 08-12-2014, 09:23 AM
bgall's Avatar
and split ring ground will attach between the coax connector and mounting bracket without touching the inner core of the threaded adapter.
bgall is offline
post #16 of 18 Old 08-12-2014, 09:25 AM
Did you make sure to grind down the inside of the hole and the bottom of the mount where the firestik adapter mounts to? Those need to be clean metal.
More Cowbell
post #17 of 18 Old 08-13-2014, 01:42 PM Thread Starter
bass5money's Avatar
yes.. I finally got a reply from rightchannel. they are sending me another system, he even agreed i was doing everything right.. I'll post up what happens when get the new one..
post #18 of 18 Old 08-19-2014, 06:14 PM
Where do you have antenna mounted to? Sounds lik possible bad radio. Ive seen a lot of bad grounds that mad no noise just coult transmit or receive
bhiland is offline
