30 AMP Relay??? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 12-26-2009, 11:20 PM Thread Starter
07unlimitedx's Avatar
30 AMP Relay???
So this might sound like a dumb question to some of you... but... on a 30 AMP relay... what does the 87A connection do, or what is it for?
Thanks and Merry Christmas to everyone!
07unlimitedx is offline
post #2 of 7 Old 12-26-2009, 11:40 PM
zjr
zjr's Avatar
With auto style relays the 87a is a normally closed circuit. This means that the circuit will be complete until the relay is energized and that will turn off the circuit.
zjr is offline
post #3 of 7 Old 12-26-2009, 11:41 PM Thread Starter
What would it be used for?
post #4 of 7 Old 12-26-2009, 11:53 PM
venom's Avatar
it lets you essentially wire a relay to work 'backwards'
so you can turn things off with it instead of on
Originally Posted by My Wife
venom is offline
post #5 of 7 Old 12-26-2009, 11:56 PM
zjr
zjr's Avatar
As far as I know they are mostly used for alarms in that manner. I can probably think of something later though. Anything that you want to leave on and not worry about turning off unless something activates it. Could even be used for an air intake to close off if there is water present. The circuit will hold open a valve and when a switch senses water, it could open the circuit and the flap will shut. Like I said, just ideas.
zjr is offline
post #6 of 7 Old 12-27-2009, 09:33 AM
think fuel pump with a safety trigger, or a nitrous solenoid when the fuel pressure drops too low the sending unit will signal the relay to open and shut off the nitrous so you don't melt pistons and so on.
rob4607 is offline
post #7 of 7 Old 12-27-2009, 10:33 AM Thread Starter
Thanks everyone... just curious
