4-Way Flashers ? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 5 Old 12-24-2009, 09:22 PM Thread Starter
boots's Avatar
4-Way Flashers ?
Ok all you electrical wizards.
When useing the 4-way flashers on the our JK's only the front and rear turn signals blink, is there a way to get the third brake light to blink as well ?
08 Sahara Unlimited Auto / 4.5" BDS long Arm / 37" BFG KM2s / AEV Wheels & Hood / ARB Front & Rear Bumpers Line-Xed / Or-Fab Tire Carrier Line-Xed / Atlas Rubicrawler / Cobra 75CB / JKS disco's & Trackbar Brackets / EVO "C" Gusset's / 5:13 Gears / Speedo Recal / s-Pod / Warn Powerplant / Weather Tech Mats / Ultra CB Ant Mount / MBRP SS Exhaust / Jeep Trail Guide / FabFours Rock Rails / Evap Relocate / Tom Woods Drive Shafts / LightForce 170's Mopar Brackets / Viper TB / AeroForce Gauge
boots is offline
post #2 of 5 Old 12-25-2009, 10:35 AM
jeeperjkj's Avatar
Good question.
If there is, wouldn't it then be a 5 way flasher?
jeeperjkj is offline
post #3 of 5 Old 12-25-2009, 02:15 PM
sickchilly's Avatar
Send a message via AIM to sickchilly Send a message via Skype™ to sickchilly
If you did that, you'd essentially be bridging the 3rd brake light to either or both of your turn signals. So then your 3rd brake light would flash anytime you used the left or right regular turn signals. Not good. What's the point?
2007 Jeep Green Rubicon 4-door with various bits 'n pieces... broken in but not even finished!
sickchilly is offline
post #4 of 5 Old 12-25-2009, 02:25 PM
Yep, it will then flash with the blinkers. I don't see a reason for the 3rd light to be flashing..
post #5 of 5 Old 12-25-2009, 04:27 PM Thread Starter
boots's Avatar
I was just thought if it could be done it would give extra light in an emergency situation.
With a 37" tire hanging off the back of my JK it blocks the tail lights at certain angles. I mounted my third brake light into my hardtop just above the rear wiper. Nothing to block the light that far up......
boots is offline
