Q about wiring an amp? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 16 Old 12-21-2009, 10:20 AM Thread Starter
rdhrd4's Avatar
does any one know (if its possible) how to wire an amp to the stock jk radio?
rdhrd4 is offline
post #2 of 16 Old 12-21-2009, 10:25 AM
BeerMonkeY's Avatar
yes. do you have the infinity system?
'92 YJ
'13 WK2
BeerMonkeY is offline
post #3 of 16 Old 12-21-2009, 10:37 AM Thread Starter
rdhrd4's Avatar
negative... stock radio that came with the heat and air "X"
rdhrd4 is offline
post #4 of 16 Old 12-21-2009, 10:41 AM
BeerMonkeY's Avatar
you will need a low level converter (sometimes called a high/low converter) it will hook into the stock speaker wires and make it so you can hook up a set of rca cables to run into your amp. are you just adding a sub amp?
'92 YJ
'13 WK2
post #5 of 16 Old 12-21-2009, 10:43 AM Thread Starter
rdhrd4's Avatar
yes im just wanting to add an amp for a sub, so i was hoping for a way to connect an amp directly to the stock radio much as you can with an aftermarket radio... i know it can be done without tapping into the existing speaker wires, i just dont know how...
rdhrd4 is offline
post #6 of 16 Old 12-21-2009, 10:46 AM
BeerMonkeY's Avatar
you will need some kind of interface unless you have a amp that has a speaker level in, which is a speaker wire connection into the amp instad of rca cables. if it does you will still need to splice into the facotry speaker wires. theres no rca out on a stock radio
'92 YJ
'13 WK2
post #7 of 16 Old 12-21-2009, 10:55 AM Thread Starter
rdhrd4's Avatar
is this how it would work?
rdhrd4 is offline
post #8 of 16 Old 12-21-2009, 11:41 AM
SONIC's Avatar
You will need a line level converter.
Tap into the speaker wires in the sound bar. The line level will give you RCA output. Run that RCA cable to your amp input. From there just wire like any amp install.
And your above diagram is wrong. You only connect the amp to the speaker level wires...no connection to the radio as it doesnt have RCA outs.
speaker wire------> line level converter------> rca cable-----> amp input------> subs
and of course youll have to run your power ground and remote wires as well
-Doc Holiday
SONIC is offline
post #9 of 16 Old 12-21-2009, 01:40 PM Thread Starter
rdhrd4's Avatar
know where to find a "line level converter"? or how much it will be?
also where will the remote wire hook to? isnt that usually the blue wire on the harness of the aftermarket radio?
rdhrd4 is offline
post #10 of 16 Old 12-21-2009, 02:21 PM
groovy55's Avatar
I just did this project myself and completed it yesterday.
I have the MyGig (Non Nav) and non infinity system.
I used the following:
PAC Harness (Allows you to keep all volume/fade controls intact.)
Alpine PDX.4 (4 channel amp to run the factory speakers)
Infinity Basslink (200 watt powered sub)
The hardest part is getting the harness jammed in behind the dash, but it will fit. I'll tell you this...I am extremely happy with this set up, it sounds awesome.
groovy55 is offline
post #11 of 16 Old 12-21-2009, 03:38 PM
SONIC's Avatar
A line level can be purchased at any audio store or best buy, even walmart maybe but heres a link
http://www.crutchfield.com/p_142LOC8...0.html?tp=1276
and the remote....
your right it runs to the head unit often, but in the JK with stock headunit the easiest way is to run the remote wire to the DRIVER SIDE power outlet. It is a good switched power source. *the passenger side one is always on)
-Doc Holiday
SONIC is offline
post #12 of 16 Old 08-09-2010, 06:47 PM
jerryn's Avatar
Can you explain how you added the Alpine AMP?
I'm interested in doing this. I just ordered 4 new speakers and I'd like to
add an amp to the factory head unit. Can you explain more how you did this? What was involved with modding the PAC interface cable ?
jerryn is offline
post #13 of 16 Old 02-06-2011, 10:07 AM
cherokee980's Avatar
what about adding an amp to the Infinity system? Is it more than just hooking up a line out converter?
cherokee980 is offline
post #14 of 16 Old 02-06-2011, 04:26 PM
Kiltstain's Avatar
Here's a more detailed diagram.....
2007 Sahara 2dr, 3.5" RK X Factor Plus Long Arm, Dana 44 Rubicon front axle w/locker, Dana 44 Rear, Poison Spyder BFH w/stinger, Poison Spyder fenders F&R, Poison Spyder Rocker Knocker, 37" Pitbull Rockers Bias Ply, 17x9 Spyderlocks, 1350 Drive shafts, Hard Rock 4x4 Rear bumper w/tire carrier & gas can mounts, Poly Pro front axle tube, Poison Spyder evap skid. Upcoming: RR Snorkel, Skid plates
Kiltstain is offline
post #15 of 16 Old 02-06-2011, 09:39 PM
babiehughie's Avatar
You forgot the 710 cap.
Originally Posted by STUPIDFACE View Post
I have 2 legs, but 3 knees....right knee.....left knee.....wee knee....
Jack of all Trades, Master of Some
babiehughie is offline
post #16 of 16 Old 02-09-2011, 09:45 AM
douche! LOL
