2007 horn not working - JKowners.com : Jeep Wrangler JK Forum
post #1 of 15 Old 07-07-2014, 04:19 PM Thread Starter
horn quit working/ ck 2 fuses looks ok.// also i have a problem w/right side front blinker park light. blinker will work but quits when i turn on park lights on. I read an earlier thread about multifunction switch in which might be the park light prob. //First post, hello to all
westvirginiaclay is offline
post #2 of 15 Old 07-07-2014, 08:12 PM
Cruise control work?
post #3 of 15 Old 07-07-2014, 09:14 PM Thread Starter
I don't know, have not used it in a while
post #4 of 15 Old 07-08-2014, 06:32 AM
Do you have the airbag light on the dash?
post #5 of 15 Old 07-08-2014, 10:58 AM
my horn went too last week, it works but is really muffled sounding, almost can't hear it when arming the door locks
Blacked out 07 JKUR, safari straps, Treadwright 35's on stock rims and Spydertrax spacers, stubbied front bumper, trimmed flares, 2" body lift, 2" spacers in front with 1" spacers in rear, Gen Right Tire carrier, more to come!
Badd Andy is offline
post #6 of 15 Old 07-08-2014, 02:28 PM Thread Starter
cruise control works. no airbag light on. Blinker problem;from what I have determine I'm not getting a ground through park light socket but I'm getting power to it. i have cleaned ground for light on body. Dealer told me the ground goes through multifunction switch for light and HORN. I have ordered switch from advance auto [80$ dealer 130$} PS, the blinker works but quits when i turn on park light. Give update when multi-switch gets here in 2 days
post #7 of 15 Old 07-08-2014, 02:44 PM Thread Starter
to clear up, the horn works off the same multifunction switch as blinkers but not the same ''ground''
post #8 of 15 Old 07-22-2014, 08:49 PM Thread Starter
Multifunction switch did not fix it. now the left park light out. horn out, front park and blinkers not working. only getting 3.5 volts to lights.
post #9 of 15 Old 07-23-2014, 02:20 AM
BumpInTheRoad's Avatar
You're problem is easy. Horn is filled with water/mud. Give it a week or two and it will return to it's normal strangulated goat sound.
I'm a JKO Reject
BumpInTheRoad is offline
post #10 of 15 Old 07-31-2014, 02:52 PM Thread Starter
horn, front park lights and blinkers FIXED/// the problem was a ground wire from steering column to computer [timp] beside batterie under hood. dealer spent few hrs trying to fig out. Had hidden broken ground. dealer ran new separate ground instead spending too much time finding break in wire. Dealer said solder joints break in wires, causes probs. dealer also said if you have a lot of miles with no probs with computer, you won't have any later on. i got 100000+
post #11 of 15 Old 08-01-2014, 11:37 AM
md_rubi's Avatar
mine didnt work due to the rusty contact from getting wet. I cleaned the rust off and works like a champ
md_rubi is offline
post #12 of 15 Old 08-01-2014, 03:54 PM
well, true to your word, it did in fact fix itself, and yes still sounds like a strangled goat, lmao
post #13 of 15 Old 08-24-2014, 06:31 PM
I have this exact same problem. I am wondering if you have some more info on the fix. I know if I take it to the dealer they are still going to spend hours troubleshooting... If you can post pics of the wire they installed and where it goes??? Id appreciate it....
WarDamn is offline
post #14 of 15 Old 07-01-2018, 06:34 PM
I am having the same exact problem as well. Does anyone know where I need to run this ground wire at the column and to the TIPM? Any help is appreciated
bans25 is offline
post #15 of 15 Old 07-01-2018, 07:47 PM
After tearing my hair out for a while I found the issue.. I am posting the video in case others find this thread during a search. My issues were exactly like the OP but in a 2008 JKU.
In the end, bad ground point.. will need to cut off the ring terminal and make a new one..
bans25 is offline
