Headlight Help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 06-23-2014, 11:49 AM Thread Starter
Headlight Help
I know there is a ton of info on headlights on here, but after reading the majority of it, I'm still unsure. We just bought a new 2014 Jeep Wrangler Unlimited and everything I've read says the lighting is terrible. I would like to upgrade it but don't want to spend a fortune. What would everyone suggest under $200 (the less, the better). We live in a suburb of Chicago and there is a lot of two-road driving on rural roads (cornfields and deer). We also go to northern Wisconsin a couple of times of year (deep woods). Thanks!
pmsmith2032 is offline
post #2 of 4 Old 06-23-2014, 04:16 PM
DrWardner's Avatar
For under $200, I'd go with some LED replacement bulbs. You could do HID's as well, but they are not legal and if you don't have nice ones with high and low beam, you'll end up blinding people. Trucklites would be the best option, but they are at least $400 from most venders.
2013 JKU Sahara: 3.5" RK springs, Fox resi shocks, Synergy high steer kit, DIY-PSC Hydroassist, JKS quick discos, LŌD rear bumper and sliders, ARB stubby front, 37" BFG KM2, 17" XDSeries Rockstar2, Warn M8000, Rigid lights, Chinese lights, RR Modular Snorkel, G2 4.56 gears & diff covers, Detroit TrueTracs front & rear, Artec Truss & c-gussets front, RCV's front, Tom Woods 1310 Front shaft.
DrWardner is offline
post #3 of 4 Old 06-23-2014, 08:59 PM
USAFJK's Avatar
I went with Lifetime LED's. Pretty bright but there is a draw back. Basically you don't have a high beam, I mean it's there but not noticeable. Installing them is pretty easy too. Just make sure you zip tie the connectors together since they do not lock and when putting them in the lens, you need to give them a twist at the bulb or else you get a lopsided beam. They are about $150 a pair.
2012 JK Sport, 6 Speed, Hard Top, 3" Fox lift, K&N CAI, Pioneer and Kicker Upgrade, 35" MT/R's, 15" TKO's, Sleeved and gusseted, RSE rear w/carrier, PSC Bombshells front and rear, gas mileage- dropping
USAFJK is offline
post #4 of 4 Old 06-23-2014, 09:36 PM
BumpInTheRoad's Avatar
Gil (usmcdoc14) put a lot of time and effort into testing various upgrade options that is worth taking your time to read: https://www.jkowners.com/forum/showthread.php?t=85577
The first thing, and I can verify this from personal experimentation, upgrading just the bulbs themselves with more expensive H13 bulbs is not going to make a significant difference. The reason is that the OEM reflector itself has a dead spot in the middle of the light pattern.
However, it does seem from Doc's tests that replacing the H13 bulbs with HID capsules not only generates more light but a much better light distribution pattern, and without the unfocused glare usually associated with HID drop-ins. At least this was true with the Rebel Offroad HID upgrade, and is probably true for other HID drop-ins as I'm pretty sure that Rebel didn't have the capsules custom-made. The good news is you can order HID drop-ins for under $100 off Amazon.com and return them for full refund if they turn out to not produce the quality of light you want. Remember when ordering HID drop-in kits you need Lo/Hi beam with H13 connectors and an anti-flicker harness option.
I've never seen H13 LED drop-ins in use and it's extremely hard for me to believe that they can produce any better brightness or quality of light versus a good H13 halogen bulb. There just isn't enough surface area to dissipate the heat needed, or to even mount LED elements within the focal zone necessary for a proper pattern of light. Also, unlike HID's which use ballasts to boost the rather weak voltage the OEM bus presents at the headlights, the LED's would need additional circuitry to regulate voltage to an optimum level, and again, there just isn't enough room to incorporate the additional circuitry using components that can withstand long-term use at high power draw.
The option that's worked well for me is replacing the OEM headlight lamps with quality H4 E-Code lamps such as from Bosch, Cibie or Hella and good bulbs from Osram or Hella, in combination with a full replacement wiring harness to run the headlights via relays off the battery, with the relays triggered by the OEM headlight wiring. Again, you have to incorporate an anti-flicker harness (or connect capacitors and diodes across the relay trigger terminals) to filter-out CAN BUS signals. You can buy the H4 lamps and bulbs for $80-$130 and buy the components needed to do a plug-and-play wiring harness with no splicing or soldering for around $70.
In my unscientific comparison, my Bosch H4 e-Code lamps with Hella H4 100/80W bulbs produces similar reach and pattern to $800 J.W.Speaker LED's for 1/4 the price.
I'm a JKO Reject
BumpInTheRoad is offline
