stereo questions - JKowners.com : Jeep Wrangler JK Forum
post #1 of 14 Old 12-09-2009, 02:17 PM Thread Starter
stereo questions
I've got the single cd with a sub in the rear stereo and I don't see anything on it that says Infinity. Am I to believe that it is just a basic stock stereo? If it is Infinity then how would I know? And where would the amp be located? Looking to pull the headunit and install aftermarket but don't want to start till I know what I'm dealing with. THanks.
rush2112 is offline
post #2 of 14 Old 12-09-2009, 02:23 PM
Dr.Dirty's Avatar
Feedback: 21 reviews
the amp is located under the steering wheel
and if you do change it dont get the metra harness it sucks ass big time
there is an acess panel under the plastic trim below your steering wheel and the amp is in there
www.jeepasylum.com
Dr.Dirty is offline
post #3 of 14 Old 12-09-2009, 02:49 PM
Bought my aftermarket stuff from crutchfield... their harness works great
scene: Agaudo smashes cockroach to provoke ventura
Agaudo: Homicide!, ventura how you gonna solve that one?
Ventura: Good question Agaudo,first I'd establish a motive..in this case the killer saw the size of the bugs dick and became insanely jealous!
jkjones is offline
post #4 of 14 Old 12-09-2009, 05:47 PM
When I put in my aftermarket stereo I did not use the XSVI-6522 harness that was recommended because I couldn't find it for any less than like $60. Instead I just bought a regular 71-6522 harness and installed with that, a $10 harness. The only reason the XSVI model is recommended is to retain the radio on function for the 30 seconds or so after you turn the key off. I didn't care for that anyways. If you go with just the regular harness without the retained function you have to find an ingnition controlled power lead for the IGN wire on the stereo. There is a (I believe, I will look later) pink wire with a white stripe that is in the harness under the steering wheel and going down into the dash. Just splice into that wire for your ignition keyed source on the stereo (the red wire). Just match all of the rest of the wires on the new harness to your new stereo and plug it in, works like a charm.
My sig is HUGE in Japan
Jscwerve is offline
post #5 of 14 Old 12-10-2009, 08:10 AM
groovy55's Avatar
Harness
When you use an aftermarket harness...does the piece that plugs into the back of the OEM stereo plug into the aftermarket harness...or does it plug directly into the jeep wiring, therefore eliminating the stock harness?
Reason I ask is when I installed my amp w/ a stock MyGig I cut into the factory harness to hook up the PAC harness. I think I may go aftermarket HU now and need to know if I need to buy a new OEM harness...mines kinda toast.
groovy55 is offline
post #6 of 14 Old 12-10-2009, 08:45 AM
dodge8604's Avatar
You'll wanna get a new OEM harness, at least in my opinion its the easiest way...plus it keeps things fairly simple if you go to swap HU's again
08 JKU X - Flame Red w/ a few Doo Dads
dodge8604 is offline
post #7 of 14 Old 12-10-2009, 09:02 AM
groovy55's Avatar
Thanks...any idea where I can get one?
groovy55 is offline
post #8 of 14 Old 12-10-2009, 09:31 AM
groovy55's Avatar
Never mind I found one...thanks.
groovy55 is offline
post #9 of 14 Old 02-22-2010, 10:23 PM
Exclamation
Is this what everyone does? seems silly that crutchfield is saying you need a $130 adapter to just plug in a stereo.
Bad_CRC is offline
post #10 of 14 Old 02-22-2010, 11:58 PM
If there is a sub woofer in the back, then you have the Infinity system. If you buy an aftermarket stereo, then that won't work with the Infinity amp, and you will have to redo the wiring so the aftermarket head unit connects to the speakers.
Rednroll is offline
post #11 of 14 Old 07-26-2010, 08:26 AM
I want to try to splice into the red and grey wire on the end of the stock harness that plugs into the stock HU for this. does anyone know if that will work or just go with the cig lighter? This is on an 09'
Canadian JKer is offline
post #12 of 14 Old 02-06-2011, 10:10 AM
cherokee980's Avatar
so what parts are required to add an aftermarket amp with the infinity system? Keep in mind, I am going to keep/use the OEM headunit. I just want to add an amp and a pair of subs.
cherokee980 is offline
post #13 of 14 Old 02-09-2011, 11:54 PM
cardenasrc51's Avatar
going to add my question here, i had experience instaling stereos, amp, speakers, but that was in 1992! I don't want to buy the crutchfield harness for $160. I will however buy a 4 channel amp and new Alpine head unit. Im just gonna go old school and take my test light to find my power, and switched power. splice my new stereos harness, wire up my amp, run all new speaker wire and dump the stock infinity amp off a cliff. Then i will chug a beer burp loudly, turn the key on and get some sick ass tunes. Good plan???By the way, I can't beleave how much this crap has gone up in price, geez.
2008 Unlimited Rubicon automatic with 35" KM2
15" black procomp 8069
Swag Offroad tailgate conversion
OR-Fab Tire carrier with Amo can for straps & tools
K&N cold air intake
Magnaflow exhaust
Alpine iDA-X305S
MB Quart 4 channel amp
MB Quart 6" Components
Pollk Audio 6" components
cardenasrc51 is offline
post #14 of 14 Old 02-10-2011, 02:46 AM
Rottenbelly's Avatar
That's the way to do it old school!! If you are gonna run stuff off a amp you could pull unswitched/ battery power from the cigar plug on the passenger side and switched from drivers. Then run your plugs and amp wires and be done with it. Gonna have to run speaker wire from amp but that's nothing a coat hanger and some electric tape can't take care of.
When they told me 160 for a harness I laughed in there face and said nevermind I can take care of it myself!!!
Took about 2 hour to get my headunit, amp and speakers wired up.
You smell that?
Rottenbelly is offline
