Front Turn Signal Wire Colors Question - JKowners.com : Jeep Wrangler JK Forum
LinkBack Thread Tools
Old 06-18-2014, 02:44 PM Thread Starter
Kpalas's Avatar
I have a 2014 JKU, and I put LED bulbs in the front turn signals, and I need to put resistors to stop the fast blinking, but I don't know which wires to tap into. The three wires are black, white with green stripe, and white with black stripe. This is probably very basic but I know next to nothing about this kind of stuff.
Kpalas is offline
Old 06-18-2014, 03:22 PM
Ok read in here.
https://www.jkowners.com/forum/showthread.php?t=24443
Installation of LEDS and Load Resistors:
Just like regular bulbs. Twist the bulbs wiring harness and the lights will come out. LEDs only work in one direction so if they don't light up, turn them around. For the front turn signal load resistors, attach them to the ground wire and to the outside (not center) power wire. For the rear, attach the load resistor to ground and to the brake light wire (as opposed to the running light wire). I forget which one this is, but I think there was an indication on the plastic and I remember it being the odd-wire-out. I will try to snap a picture later. I used quick splices to tap into the wires. Make sure you have long wires to mount to load resistors as they get hot and will need to be mounted to metal. For the front turn signals mine are sitting in this metal half-cup thing directly behind the turn signal and the tail light load resistors are sitting on the body behind the tail light. With these load resistors I have stopped hyper-blinking and every thing appears to be working normally.
Old 06-18-2014, 03:31 PM Thread Starter
Kpalas's Avatar
Thanks!
Kpalas is offline
Old 12-29-2015, 02:07 PM
Just completed the mod that allows fender lights to blink in sync with turn signal
On your turn signal lights, the black wire is ground, the middle wire is park and the wire furthest from the black wire is the turn signal.
weaver3110 is offline
