LED wows - JKowners.com : Jeep Wrangler JK Forum
post #1 of 12 Old 06-17-2014, 10:57 PM Thread Starter
LED wows
The short of it, Installed truck lites with anti flicker thingy = no problems
Installed TnT guardian with LED taped into factory fogs (per instructions) now getting
B16F9 - FRONT LEFT FOG LAMP CONTROL CIRCUIT HIGH
B16FD - FRONT RIGHT FOG LAMP CONTROL CIRCUIT HIGH
B162C - LT LOW BEAM CONTROL CKT HI
B1630 - RIGHT LOW BEAM CONTROL CIRCUIT HIGH
Just short of running a standalone harness what can I do to fix this? I cleared the codes via flashpax but they came right back in. TIA
2013 JKU Sport, RE 2" w/Bilsteins 5100, 315/75/16 Toyo Open country on stock wheels 1.5" spacers, AFE intake and 3in Cat-Back SS-409 Exhaust Systems, superchips flashpaq, AEV front CA drop brakets, EVO rear rock star skid/shock lift, trek armor seat covers/seat heaters, spiderwebshade, truck lite LED's.
Handful of cream is offline
post #2 of 12 Old 06-17-2014, 11:16 PM
2013 and up has a different wiring harness and its very screwy . you can't really mess with the electrical system ( tie anything into it) . best bet is to wire those fogs up to their own switch
CraigP is offline
post #3 of 12 Old 06-17-2014, 11:49 PM Thread Starter
Even with less draw? I have no problems with running a standalone just didnít think it would be necessary. What gets me is the codes come in without turning the fogs on. I was thinking I blew the module.
post #4 of 12 Old 06-18-2014, 12:07 AM Thread Starter
Just found this: https://www.jkowners.com/forum/showthread.php?t=193842
What's the difference?
post #5 of 12 Old 06-18-2014, 04:35 AM
Do the lights work? If-so, what's the reasoning to fix those faults? They aren't going to adversely affect your Jeep other than storing that code within the ECU.
post #6 of 12 Old 06-18-2014, 05:22 AM Thread Starter
Light's do work, just don't want the CEL to be on.
post #7 of 12 Old 06-19-2014, 11:47 PM Thread Starter
Quick update, the CEL and codes cleared with no interaction from me. This must be the jeep thing everyone talks about.
post #8 of 12 Old 06-20-2014, 07:34 AM
Abadjeeper's Avatar
I have some of the codes but I have never gotten a CEL because of them. I need to put capacitors on my Dually's so they don't flicker after I shut the Jeep off.
Abadjeeper is offline
post #9 of 12 Old 06-24-2014, 12:15 AM Thread Starter
New revelation, Now the TNT LEDís come on when I open the door but only dim. Shorta mimicís the dome light but not really. Iím going to file this one in the I donít give a fuck bin.
post #10 of 12 Old 07-03-2014, 10:17 AM
MatthewDrakeNC's Avatar
Send a message via Skype™ to MatthewDrakeNC
LED Swap 201U
I'm running LED's on my 2013 JKU with no problems. I swapped the OEM Bumper mounted Fog Lights with Baja Designs Squadrons and didn't see any issues....
I actually just pulled the old lights off, wired the new ones right on to the old factory harness and was good to go.
In fact, I use them just like the OEM's - with the turn signal switch on the steering wheel....
I'm not sure if you really want to make any changes - but usually when working on a "finicky" electrical system such as the new JK's requires adding a relay...
There are harnesses that you can use that include a relay which will alleviate your problems...
Thanks to all our WarFighters - Past, Present and Future - without you we would not enjoy the freedoms we have today!
MatthewDrakeNC is offline
post #11 of 12 Old 07-13-2014, 01:03 PM
I just saw those codes on my 2009 Wrangler when reprogramming.
I assumed it was due to replacing the stock bulbs to the Truck Light 27270C.
I cleared the codes but if they come back I'm not worried about it, the trucks been fine since the new bulbs.
PLUS I'm going to replace every incandescent on the truck with an LED, posting questions about that now. So I suspect that even if I buy the ones rated for canbus compliance I'll get codes.
Unlimited_Fun is offline
post #12 of 12 Old 07-13-2014, 01:05 PM
bass5money's Avatar
Bought an spod hooked up led to em ..no flicker!!!!
2014 jk oscar mike edition. Manual. 3.5" Rubicon super flex suspension lift. 35" AT tires 17" method rims. Body armor doors. Smitty built MOD front bumper. Smittybilt 9500 lb winch, ARB twin compressor, Spod with gauge, D2 LED's.
bass5money is offline
