Rigid D2 Driving Lights with OEM Foglight Wiring? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 06-10-2014, 06:00 PM Thread Starter
Kpalas's Avatar
Is there any issues wiring up a set of Rigid's D2 driving lights to the JK OEM foglight wiring?
Kpalas is offline
post #2 of 17 Old 06-10-2014, 06:04 PM
PhrogMech46's Avatar
No issues here.
See Garage for Mods
PhrogMech46 is offline
post #3 of 17 Old 06-10-2014, 06:08 PM Thread Starter
Kpalas's Avatar
Cool, thanks! And Semper Fi!
Kpalas is offline
post #4 of 17 Old 06-10-2014, 06:43 PM
jason mac's Avatar
You might run into flickering. We did when we installed them into the factory wiring. We ran a Rigid wiring harness and used the factory wiring for the switch.
jason mac is offline
post #5 of 17 Old 06-11-2014, 01:37 AM
mrsig's Avatar
I had no problems. Just cut the wires and connect them added heat shrink and they work great.
It was very smoky out when I took the photo.
CEO of Black Sheep 4x4s
mrsig is offline
post #6 of 17 Old 06-11-2014, 02:34 PM
usmcdoc14's Avatar
never had flickering due to canbus..had flickering due to some other issues
but the fog light wires will handle the amp load of LED's no problem. I am running a 10" bar that was plugged in for a while with no issues
usmcdoc14 is offline
post #7 of 17 Old 06-11-2014, 02:45 PM
Random Dude
Originally Posted by mrsig View Post
[HIJACK]
Is your bumper filled with expanding foam on the back side?
I can't figure out what else this would be.
[/HIJACK]
ExWrench is offline
post #8 of 17 Old 06-11-2014, 03:01 PM
coilrod's Avatar
No issues, lod mid width front bumper. Hard to aim well though.
coilrod is offline
post #9 of 17 Old 06-12-2014, 08:09 AM
bass5money's Avatar
I get flickering even if not using them. connected to stock wiring using rigid disconnect. 2x2's on front bumper... any way to fix??
2014 jk oscar mike edition. Manual. 3.5" Rubicon super flex suspension lift. 35" AT tires 17" method rims. Body armor doors. Smitty built MOD front bumper. Smittybilt 9500 lb winch, ARB twin compressor, Spod with gauge, D2 LED's.
bass5money is offline
post #10 of 17 Old 06-12-2014, 05:15 PM Thread Starter
Kpalas's Avatar
Ok, Thanks everyone!
Kpalas is offline
post #11 of 17 Old 06-13-2014, 02:13 PM
I cured the off flicker problem by wiring in a 6800uf 25v 105c capacitor in parallel on each of the fog light harnesses when i was splicing in the rigid connector
pay attention to the capacitors polarity you want to get it right
if you cant find the caps locally there are several vendors on ebay selling them
LittleRed is offline
post #12 of 17 Old 06-13-2014, 02:21 PM
LOD mid here too
if you are willing to have the led mounted a little deeper in the bumper the lights are much easier aim
its just a matter of adjusting the bracket so the lights sit a little deeper in the bumper, this gives a much wider range of vertical adjustment
post #13 of 17 Old 06-14-2014, 01:07 AM
mrsig's Avatar
[HIJACK]
[/HIJACK]
Yes marine foam to keep the crap out of the bumpers. I did the front and rear a long time back.
mrsig is offline
post #14 of 17 Old 07-03-2014, 10:31 AM
MatthewDrakeNC's Avatar
Send a message via Skype™ to MatthewDrakeNC
Where did you get the Marine Foam - can you tell me the brand and where to buy it?
I'd like to do the same to protect my harnessing a little more....
Thanks to all our WarFighters - Past, Present and Future - without you we would not enjoy the freedoms we have today!
MatthewDrakeNC is offline
post #15 of 17 Old 07-04-2014, 01:16 AM
mrsig's Avatar
Boat Owners Warehouse. It is way cheaper than West Marine.
mrsig is offline
post #16 of 17 Old 07-13-2014, 01:07 PM
bass5money's Avatar
They usually flicker even when not using them. Installed spod and no more flicker
post #17 of 17 Old 07-16-2014, 10:38 AM
What am I missing - how could the lights flicker when they are off? Confused.....
2013 Commando Green JKU - Magnaflow CatBack, AFE Cold Air, Lift and Tires after warranty runs out....!
BurkeDad is offline
