Turn Signal Mirrors - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 11-24-2009, 05:46 PM Thread Starter
Turn Signal Mirrors
I don't know if this is the right place for this question, but it has wires sticking out of it so, here goes. Rugged Ridge has a set of JK mirrors with turn signals built in them, does anyone know of these or has purchased a set. How are they? What about electrical hook up? Thanks.
ENTRAIL is offline
post #2 of 4 Old 11-28-2009, 06:55 PM
JimmyJK's Avatar
Rugged ridge sells the turn signal mirrors for 87-02 wranglers. Not the JK. Personally, I hope they come out with a JK turn signal/heated/relocation combo. Side note: I think I'd like to hole-saw the bottom of my turn signal housing and install a super bright LED with a very low amp draw and tie it into my dome lights. That way when I hit the UNlock button on the key-fob, it'll illumnate the surface below the door (quick check for ice and varmits) too. SOOOO, if RR makes the combo, I'll install the light at the same time.
What do YOU think?
JimmyJK is offline
post #3 of 4 Old 11-28-2009, 07:29 PM
venom's Avatar
I dunno about getting more wires into the door
I guess you'd have to have another harness to plug and unplug when removing the doors
good idea, but my doors are on and off too much!
What I did on my old YJ when I added power locks to the half doors was use a set of street rod style contacts in the door sill instead of running wires.
That also how the 3rd brake light is powered on my hearse (from the factory)
That might be cool....
one part goes on the door, the other the sill, and they make contact when you close the door, you can get 1-5 contacts
Originally Posted by My Wife
venom is offline
post #4 of 4 Old 12-01-2009, 08:05 PM
JimmyJK's Avatar
Entrail... you out there? What'r yer thoughts about this shite?
JimmyJK is offline
