E-Disco/Sway Bar Light - JKowners.com : Jeep Wrangler JK Forum
post #1 of 21 Old 11-23-2009, 12:46 PM Thread Starter
Slow and Low
Co4Lo's Avatar
Anybody figure out how to kill the flashing Sway Bar light after removing the E-Disco? Maybe jumping a couple wires on the remaining connector or something?
Co4Lo is offline
post #2 of 21 Old 11-23-2009, 02:16 PM
Broncojohn's Avatar
I think the procal is the only way.
Broncojohn is offline
post #3 of 21 Old 11-23-2009, 02:21 PM
Openly Hostile
Procal.
Jason
SDMF is offline
post #4 of 21 Old 11-23-2009, 03:04 PM Thread Starter
Slow and Low
Co4Lo's Avatar
Procal schmocal! I'm gonna figure out how to hack it...
Co4Lo is offline
post #5 of 21 Old 11-23-2009, 03:10 PM
Openly Hostile
Let us know if you figure it out, I can tell you that jumping wires wont work.
Jason
SDMF is offline
post #6 of 21 Old 11-23-2009, 03:12 PM
Yup, CAN is a bit smarter than that. The tuner will take that out of the circle of modules that need to respond on the bus. Like an X or Sahara. But let us know you're cure!
post #7 of 21 Old 11-23-2009, 03:20 PM Thread Starter
Slow and Low
Co4Lo's Avatar
So you tried this?
I would imagine that if you can figure out which leads make contact in the disco motor when the bar is engaged, and trace those up to the connector...
Basically make the CAN think it's engaged?
Co4Lo is offline
post #8 of 21 Old 11-23-2009, 03:24 PM
Openly Hostile
So you tried this?
When I first took mine off, 18 months or so ago I tried. You'd need something to duplicate the signal that the disco returns to tell the computer it's status.
Jason
SDMF is offline
post #9 of 21 Old 11-23-2009, 03:34 PM Thread Starter
Slow and Low
Co4Lo's Avatar
So you don't think it's as simple as an open/closed, engaged/dissengaged circuit signal?
I just find it odd that we have found the wire to tap into for disabeling the ESP, and manually override our lockers, but nobody has figured out how to hack the sway bar light. There's gotta be a way.
Co4Lo is offline
post #10 of 21 Old 11-23-2009, 03:49 PM
Openly Hostile
The charger guys figured out the G12 module interrupt for esp before the JK was out...since the computer shuts the ABS and ESP down if it can't talk to that module. The locker mod is just bypassing the relay. Both those mods piss the computer off and cause it to flash lights tho, kinda of the other direction from getting it to stop a flashing haha.
Hopefully you nail it - I think it is going to be like the airbags and the only way you are going to trick the computer is by building something to replicate the signal it is expecting. If someone knew what it was expecting that would obviously help a lot.
Jason
SDMF is offline
post #11 of 21 Old 11-23-2009, 04:19 PM
SONIC's Avatar
LOL
check this out
https://www.jkowners.com/forum/showthread.php?t=14449
-Doc Holiday
SONIC is offline
post #12 of 21 Old 11-23-2009, 04:45 PM Thread Starter
Slow and Low
Co4Lo's Avatar
Originally Posted by SONIC View Post
Yeah, I saw that a while back. Goofy azz chit maing!
This is super-ghey. I'll see what I can do, and report back with whatever I fawk up.
Co4Lo is offline
post #13 of 21 Old 11-23-2009, 05:07 PM
Broncojohn's Avatar
Good luck, I've been doing some reading and inside all that garbage in the swaybar is a chip that sends out a data stream that tells the status of the bar. I'd bet if you isolate the chip and hook it up with the correct inputs to it you would be fine. Otherwise we're SOL. The bus is designed to run in any FU state; shorted to ground,power, or together. It may be easier to buy the PROCAL or have the Dealer remove it.
post #14 of 21 Old 11-23-2009, 06:31 PM Thread Starter
Slow and Low
Co4Lo's Avatar
Yeah... well my "Modified-Friendly" dealer got shut down. I'm left with a bunch of strict Compass lovers!
Maybe I'll just live with it.
Co4Lo is offline
post #15 of 21 Old 11-25-2009, 07:37 PM
tkob1060's Avatar
Co4lo what bar are you running now? I am thinking about getting the Currie since I drown mine finally
tkob1060 is offline
post #16 of 21 Old 11-25-2009, 07:41 PM
sickchilly's Avatar
Send a message via AIM to sickchilly Send a message via Skype™ to sickchilly
Go to the dealer and have them remove feature code SHG. It's essentially the opposite of the programming instructions on page 7 here:
http://www.mopar-accessories.com/en-...r.ashx?id=2140
2007 Jeep Green Rubicon 4-door with various bits 'n pieces... broken in but not even finished!
sickchilly is offline
post #17 of 21 Old 11-26-2009, 09:04 AM Thread Starter
Slow and Low
Co4Lo's Avatar
I'm not sure what I'm gonna run yet. Maybe a Currie, maybe a stocker with manual disco's.
Co4Lo is offline
post #18 of 21 Old 11-26-2009, 10:54 AM
chromedome's Avatar
Procal is $120. What's your time worth?
chromedome is offline
post #19 of 21 Old 11-26-2009, 01:22 PM Thread Starter
Slow and Low
Co4Lo's Avatar
I don't calculate the value of my time when I'm doing something I enjoy, ON MY OWN JEEP.
Co4Lo is offline
post #20 of 21 Old 11-26-2009, 08:26 PM
mrsig's Avatar
I had it done at the dealer.. Just go in with a computer problem and slip the tech a few bucks and your done..
CEO of Black Sheep 4x4s
mrsig is offline
post #21 of 21 Old 11-27-2009, 09:48 AM Thread Starter
Slow and Low
Co4Lo's Avatar
O.k. I got sparks and blew the fuse for the sway bar. Fawk this... going to the dealership to have it turned off once I put a different sway bar on it. (so they don't give me the safety speech)...
Co4Lo is offline
