switches - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 11-21-2009, 10:24 PM Thread Starter
dtcc687's Avatar
Question switches
so i got some kc lights and the daystar light switch panel a few months back. i only have 1 switch wired up to a 10 amp fuse and wanted to know if i can bridge the other 3 switches to the same power supply so i wont have to run new wires for every switch.
dtcc687 is offline
post #2 of 7 Old 11-22-2009, 07:40 AM
Probably not, but it depends on what you are doing.
First; This 10a fused wire comes from the battery? What gauge wire?
2nd; Is the first switch triggering the lights directly, or triggering a relay?
3rd; Are the other switches going to trigger a relay, or direct components (What?)
post #3 of 7 Old 11-22-2009, 08:10 AM Thread Starter
dtcc687's Avatar
the first switch is wired to a relay. maybe ill just run some nice size wire with a larger fuse to power the other 3
dtcc687 is offline
post #4 of 7 Old 11-22-2009, 10:39 AM
KD6QZX's Avatar
If you are pulling positive power from the battery via a fuse to the switch(s) then to a relay to actually power the lights you will be fine, most relays only need a few milliamps of power to energize and trigger. So a 10 amp fuse on say 14g wire would be more than sufficient.
KD6QZX is offline
post #5 of 7 Old 11-22-2009, 07:38 PM
sPOD-guy's Avatar
Feedback: 12 reviews
You may "Daisey-Chain" the common and the hot wires to the remaining two switches, but where are you acquiring the power? Are you going directly to the battery? Are you tapping into another power source?
-John the sPOD guy
switches jeeps panels jk-forum carling contura led switch windshield
sPOD-guy is offline
post #6 of 7 Old 11-22-2009, 08:05 PM
The Joker's Avatar
he would know!
The Joker is offline
post #7 of 7 Old 11-29-2009, 08:16 PM Thread Starter
dtcc687's Avatar
comes right off my battery to a relay then to the single switch. its the setup that came with the kc lights i bought. just wanted to know if i should run new wires with a separate fuse or not.and the switch that is hooked up is run into my fuse box running off a 10 amp fuse. the 3 other switches will not have anything hooked up to them for now i just want the other switches to light up.
dtcc687 is offline
