Led light bar instead of stock fog lights - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 05-14-2014, 09:20 PM Thread Starter
08jkkid's Avatar
Hey everyone,
i have a 2011 jku rubicon, i am running a smittybilt xrc bumper without foglights.
My question is can i wire my led light bar into the stock foglight harness? If so how would i go about doing that. Im looking to be able to turn the light bar on and off from my light stalk just like i would do to turn my stock fog lights on.
Thanks in advanced for the help!
2011 rubicon- 3" rubicon express lift- smittybilt xrc front stubby bumper- smittybilt x20 10k winch- 22.5" led light bar- procomp 152's - general grabbers 35x12.5
08jkkid is offline
post #2 of 4 Old 05-14-2014, 09:26 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Okay, first answer. Yes you can do what you are looking to do, however, you will want to wire the lights off of a relay and use the factory fog circuit to trigger the relay. LED lights have a tendency to bleed down slowly causing a weird strobing effect that oscillates back and forth (two separate lights). If you like light shows, go direct, I opted for a relay and that eliminated the strobing. You may have to cut a plug off the harness to gain access to the wiring for the relay.
Simple answer - if you can handle a basic relay control, then yes, you can do what you want to do with little fuss and no additional wiring from the battery.
JKCTAZ is offline
post #3 of 4 Old 05-14-2014, 09:44 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Little, big ass schematic.
JKCTAZ is offline
post #4 of 4 Old 05-14-2014, 09:52 PM Thread Starter
08jkkid's Avatar
perfect thank you for the quick reply!
08jkkid is offline
