ABS Disconnected - Rear tone rings info? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 11-07-2009, 05:34 AM Thread Starter
crash's Avatar
Has anyone driven an Auto. JK with the rear ABS lines disconnected?
If so did the transmision shift properly?
I know it's a crazy question!
RIVER RAIDER OFF-ROAD
717.262.3079
crash is offline
post #2 of 2 Old 11-07-2009, 05:51 AM
guinness's Avatar
My abs and pressure controller were shot after the JK had the lightning strike and the transmission did not shift properly. I could floor it and it would rev out but no speed and no shift.
The ecm and esp/bas were also shot so that could have also caused the problem. The only way the dealer found the problem w/ the pressure controller was the jk still drove screwed up after all else was fixed, so Im guessing that w/ no pressure in the rear abs lines it will drive screwy.
If you need more info I can try and dig up the service report w/ the tech terms and explanations of the problem.
Rest In Peace Guinness. You will never be forgotten. My brother and my best friend
guinness is offline
