Wipers went on the fritz - JKowners.com : Jeep Wrangler JK Forum
post #1 of 66 Old 10-31-2009, 09:31 AM Thread Starter
BigMike's Avatar
It's raining in Atlanta today and I was driving over to a friends and had the wipers on Intermittent. Then I noticed that they were on all the time. If I shut them off, they stopped right where there were and didn't go back to the bottom of the windshield. If they were on Intermittent, it was like they were on Low (all the time). High worked like it should.
I had my GPS plugged in the Power Outlet (right). When I removed the plug for the GPS and put it in the other outlet, the wipers worked normal.
Weird shi!t.
, Granite,
BigMike is offline
post #2 of 66 Old 10-31-2009, 09:38 AM
gold knight's Avatar
I haven't heard of that one. Gotta love CANbus.
I started the Jeep once and tried to roll the pw down at almost the same time. The windows stopped responding and I had to turn it off and back on before they would work again.
gold knight is offline
post #3 of 66 Old 10-31-2009, 09:50 AM
Weird shi!t.
GTFOH! I'm having a very similar issue with my wipers.....
i'm just not sure about the plug bit
dealer has replaced the combination switch twice now and installing another new wiper motor on monday
after picking it up yesterday i noticed the steering wheel lock no longer worked and the key tumbler/ignition was hard to turn!
i'm not happy at all about some hack tearing my SH&% apart!
they just seem to compound the original problems more often than fixing them
scene: Agaudo smashes cockroach to provoke ventura
Agaudo: Homicide!, ventura how you gonna solve that one?
Ventura: Good question Agaudo,first I'd establish a motive..in this case the killer saw the size of the bugs dick and became insanely jealous!
jkjones is offline
post #4 of 66 Old 10-31-2009, 09:59 AM
RiggerMike's Avatar
I'm having the same issue. It doesn't rain here much, but I'm getting better at timing the stop.
Current Mods:
  1. Cleghorn tailpipe mod
  2. Cleghorn side step ventilation with Gold Mtn. enhancement
  3. Heartbreak Ridge bumper scuffs
  4. Goler gas tank skid mod
  5. Miscellaneous pin striping
  6. Woods evap cannister relocate (Wow, an intentional mod!)
  7. 2"BB and swapped in stock Rubi coils and shocks (thanks Seth!)
  8. Calico fender realignment and texturing
  9. Calico "explodey the side step" ez removal kit
  10. Stock Rubicon rails courtesy of JackTuttle (Thanks Jack!)
  11. Solid Axle dif covers
RiggerMike is offline
post #5 of 66 Old 10-31-2009, 10:11 AM
how many miles and how long have you guys had your Jeeps?
it's my bet it's not going to be just the three of us having this issue
jkjones is offline
post #6 of 66 Old 10-31-2009, 10:24 AM
tkob1060's Avatar
leave the battery disconnected overnight or all day
tkob1060 is offline
post #7 of 66 Old 10-31-2009, 10:41 AM
that has been tried already.....did'nt work
jkjones is offline
post #8 of 66 Old 10-31-2009, 10:48 AM Thread Starter
BigMike's Avatar
'09 w/3,000 miles
, Granite,
BigMike is offline
post #9 of 66 Old 10-31-2009, 11:01 AM
'09 w/3,000 miles
dont let this get away from you take it to the dealer starting now!
if they can't fix it you need it declared a lemon before 1year/12,000 miles
i'm waiting to see what they will do with mine
jkjones is offline
post #10 of 66 Old 10-31-2009, 11:18 AM
RiggerMike's Avatar
'07 with 37,000 miles.
Current Mods:
post #11 of 66 Old 10-31-2009, 07:43 PM
07unlimitedx's Avatar
My rear wiper works once in a while... not very often... If I leave it on every blue moon it will turn on. I hooked up some 12V direct power to the motor and that works fine. Guess it's the switch.
07unlimitedx is offline
post #12 of 66 Old 10-31-2009, 08:02 PM
gt3073b's Avatar
My 07 started doing this at 39k
I've never figured out what it was, so I just time the switch to stop them at the bottom.
Bryan.
2007 JK Rubicon Unlimited Rescue Green 6 Speed
Mods Shrockworks Rails & Bumpers, Currie Lift, Tom Woods 1350 driveshafts, 35" Toyo M/Ts on ProComp 7028s
In Progress
To Do
gt3073b is offline
post #13 of 66 Old 10-31-2009, 08:05 PM
tkob1060's Avatar
has anyone had their clock spring replaced? or steering control module? everything on the dash and steering wheel are controlled by the SCM
tkob1060 is offline
post #14 of 66 Old 10-31-2009, 09:21 PM
yeah i also thought the switch was bad, been through three now....
and that was'nt it!
that really blows! i would expect that kind of thing with maybe.......
a 20 y/o vehicle not something 5 or under...unexcuseble!
Bryan.
this kind of reply I've come expect on this..... or any forum for that matter!
you clownin?.... that shat just ain't funny!?....... this is not a Jeep thing!
this is a pissed off consumer thing
jkjones is offline
post #15 of 66 Old 11-04-2009, 07:07 AM Thread Starter
BigMike's Avatar
OK, now the wipers are full time fawked up.
I used Mist this morning to wipe some water off of the windshield and the wipers wouldn't stop! No matter what I did with the switch. I shut the engine off at a stop light and turned it back on. Now they work but if I shut them off, they stop right where they are. Also, the intermitent doesn't work again.
Did British Leyland or Lucas design the CANBUS? I went through that BS years ago with my MGB.
, Granite,
BigMike is offline
post #16 of 66 Old 11-04-2009, 09:38 AM
That really sucks to hear!
I'm having part of my harness replaced when it arrives.....
jkjones is offline
post #17 of 66 Old 11-04-2009, 09:41 AM
tkob1060's Avatar
like I said the clockspring and SCM control that, unless you have short or bad ground in the wiring.
tkob1060 is offline
post #18 of 66 Old 11-04-2009, 12:04 PM
Dude I apologize,
you were being serious and not an azz
sorry again for my mis-perception!
your original post just sounded.....
jkjones is offline
post #19 of 66 Old 11-08-2009, 07:48 PM
Krunchytaco's Avatar
My `07 with 39k has the same issues!
Any word on what the fix is?
Krunchytaco is offline
post #20 of 66 Old 11-08-2009, 08:24 PM
2008, 16,4xx miles
so far..
combi switch replaced twice.....nope
wiper motor replaced twice........nope
waiting to see if partial harness replacement does the trick
tech mentioned something about poor quality in manufacturing(harness)
it's on the way....
will update when installed..........
jkjones is offline
post #21 of 66 Old 11-08-2009, 11:07 PM
2008, 16,4xx miles
so far..
it's on the way....
Thanks!
I wonder if this is one of the fine products of 'Nicaragua" thats causing the issues
post #22 of 66 Old 11-09-2009, 01:35 AM
tkob1060's Avatar
Dude I apologize,
wtf would you take my post above as clownin or being an azz???????
I asked 2 questions about 2 different parts and said what they control. how can you HEAR anything bad out of that????
tkob1060 is offline
post #23 of 66 Old 11-09-2009, 10:41 PM
dude get your panties unbunched....
honestly at first glance with all the smarta$$ comments i've seen around here
maybe i was feeling a little defensive....COME ON.. CLOCKSPRING!?
MY SHAT'S DIGITAL!
jkjones is offline
post #24 of 66 Old 11-09-2009, 10:44 PM
[QUOTE=Krunchytaco;262359]Thanks!
I wonder if this is one of the fine products of 'Nicaragua" thats causing the issues [/QUOTE
yeah our domestic products are all made in foreign countries
jkjones is offline
post #25 of 66 Old 11-09-2009, 10:49 PM
as I started reading this thread that is the same thing that came to mind.
My first bet would be on the clockspring as well. However, with this canbus **** I suppose it could be just about anything.
For those of you that have had other components replaced, have they replaced your clockspring yet?
I was wondering for the one that was having issues with the ignition afterwards if they had opened up your coloumn and took a look.
Have any of you had issues with cruise control? Airbag lights?
WTF_LOL is offline
