Where to mount switches in JK? - JKowners.com : Jeep Wrangler JK Forum
LinkBack Thread Tools
Old 04-02-2014, 05:51 AM Thread Starter
joecatch's Avatar
The more things I want to do with my new 2012 JK, the more roadblocks I run into. Seems like everything I hope to do is no where as simple as it should be in this JK.
I bought a nice Mopar light bar to mount on the bumper and I plan to add 3 lights to it, 2 flood and one long range light. Forget the fact that NYS laws may give me a hard time with this, I have a bigger issue, where to mount the 2 light switches?
I was going to mount them where the traction control and flasher switches are but someone told me that the dash is not blank behind them but has some kind of circuit board. And unlike other SUVs I have had, I don't see any other places on the dash to drill holes for the switches. And I don't really want to spend $400 on SPOD just to have 2 light switches.
So I am open to ideas; where did you mount YOUR switch? Thanks.
JC
joecatch is offline
Old 04-02-2014, 05:55 AM
Apt
I Put the FU in FUN
Apt's Avatar
A pillar?
Apt is offline
Old 04-02-2014, 06:06 AM
JKO Dickhead
Asmmns's Avatar
Search for the thread on here for switch locations.. You will get a ton of great ideas !
__________________
CURE SMA !
Asmmns is offline
Old 04-02-2014, 06:12 AM
honeybadger08's Avatar
JC
I took off that cover behind the shifter and made me a panel. Here is a pic. It wasnt hard to do, it just took time. I think Cool tech makes one like this. But I like making my own stuff.
honeybadger08 is offline
Old 04-02-2014, 06:48 AM
Grant211's Avatar
Grant211 is offline
Old 04-02-2014, 07:30 AM Thread Starter
joecatch's Avatar
That looks professional and clean. Who makes that? Thanks.
JC
joecatch is offline
Old 04-02-2014, 08:15 AM
edthesniper's Avatar
Rugged Ridge
Semper Fi
edthesniper is offline
Old 04-02-2014, 08:36 AM
JKO Dickhead
Asmmns's Avatar
I personally run the Daystar lower switch panel. I dont need more than four switches so it works for me !
http://www.quadratec.com/products/12500_243X_PG.htm
and for my in cab winch control I have this:
https://www.jkowners.com/forum/showthread.php?p=1398983
__________________
CURE SMA !
Asmmns is offline
Old 04-02-2014, 09:10 AM
mrkeefer's Avatar
Send a message via Yahoo to mrkeefer
mrkeefer is offline
Old 04-02-2014, 11:00 AM
TCdawg's Avatar
Likewise. Daystar lower panel with four switches.
Left side of dash, just above the lower speaker for Winch Control panel
Mine is an 08...ymmv in a 12
TC
TCdawg is offline
Old 04-02-2014, 11:20 AM Thread Starter
joecatch's Avatar
Bottom photo looks really cool. I have a 6 speed manual so I can't use that Daystar so I decided to do the RR panel instead.
JC
joecatch is offline
Old 04-02-2014, 12:25 PM
ADDICTION II build begins....
TXROCK's Avatar
There are tons of options as you can see from the other member posts. There are a couple vendors on here who sell switch units (like sPOD) that can help get you started (depending on your electrical wiring ability).
U.S. Army
TXROCK is offline
Old 04-02-2014, 02:08 PM
SCOUT37JK's Avatar
this was my solution for accessible switches with the 6spd
homebuilt JK - blood, sweat, lemonade. renamed LOOSE NUTS
SCOUT37JK is offline
Old 04-02-2014, 02:14 PM
Unlimited_Fun is offline
Old 04-02-2014, 03:44 PM
You only think you need 2 switches......just wait. Get a Spod.
CT Performance, Inc is offline
Old 04-02-2014, 04:55 PM
Thats why on my panel I have 4 unused switches just in case.
Old 04-02-2014, 05:00 PM
You can never have to many switches..My EB
Old 04-03-2014, 12:12 PM
terrahawk's Avatar
terrahawk is offline
Old 04-03-2014, 12:26 PM Thread Starter
joecatch's Avatar
Wow, what a nice range of solutions to the problem of mounting switches! Alot of great ideas here. Someone should make this into a sticky or something...
JC
joecatch is offline
Old 04-03-2014, 01:01 PM
TXROCK's Avatar
That's awesome!
U.S. Army
TXROCK is offline
Old 04-03-2014, 08:16 PM
A-pillar from Rugged Ridge with 4 Daystar Rockers. Super clean and right above the easy firewall access which is right above the factory ground in the drivers footwell. I also like having my switches up out of the way so no worry about accidentally flipping something on when it shouldn't be and potentially causing some issues.
tkelly311 is offline
Old 04-03-2014, 11:44 PM
Jonboy's Avatar
sPod sPod sPod.
Jonboy is offline
Old 04-04-2014, 07:22 AM Thread Starter
joecatch's Avatar
I just ordered the Rugged Ridge pillar with 4 switches for $56.
I have a 6 speed manual so I am not sure about routing the wires through the firewall but I'll figure it out.
Question on the switches, however. At night when they are lite, are they distracting at all as they are mounted up near your line of sight?
Also, do those switches come with connectors?
JC
joecatch is offline
Old 04-04-2014, 07:39 AM
I find them to be distracting some at night when they are lite. But if you have more light on the outside of the jeep it goes unnoticed.
The switches have three male connectors on the rear so you will need to put female connectors on the wires.
ajpboss90 is offline
Old 04-04-2014, 06:40 PM
TexasJeep's Avatar
rugged ridge a pillar with daystar switches, i got a terminal strip mount below the steering wheel for easy access to switch wires!
Originally quoted by :White13JKUR
My favorite was the time at the ATM when I hopped out of the jeep and a hot soccer mom immediately approached me and asked in a friendly voice: “How many inches do you have?” Then, when I looked to see that she too had jumped out of a stock jeep similar to mine, I responded with confidence : “3.5 inches”
TexasJeep is offline
