Body Armor Bumper/20" light bar - JKowners.com : Jeep Wrangler JK Forum
post #1 of 25 Old 03-27-2014, 11:43 AM Thread Starter
AppSt59Dave's Avatar
Hey fellas. Looking for some advice. I have a 20" Engo bar mounted to the Rigid 20" cradle...took some hack and tap. i am not completely sold on the current mock up. anyone know how i could mount it underneath the top of the hoop? i can not find a mount that can adjust so it will mount flush against the bar but still be able to angle correctly to mount around the tube. Maybe im not sold because the bar has to mount on the back side where the tabs are instead of directly on top....
Thanks yall.
'12 JKU, 3.5", D44 front swap w/ OX & 5.13s. CMM & Rimz One Built.
Sponsored by Rigid Industries & Method Race Wheels
AppSt59Dave is offline
post #2 of 25 Old 03-27-2014, 12:01 PM
I mounted my 12 inch bar in between the fairlead and the winch plate.
You could do something like this:
http://www.fab101.com/news/winch-fai...led-light-bar/
or this:
http://www.genright.com/ProductInfo....ductid=LEDFLMF
Just suggestions to get your mind working, I can't find any mounts for a 20" bar. Looks like you have enough room to mount it this way.
post #3 of 25 Old 03-27-2014, 12:08 PM Thread Starter
yeah, i have seen those designs and I do like them...maybe I can get Brian and Jeremey over at CMM to build one for the masses.
post #4 of 25 Old 03-27-2014, 12:22 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Depending on the room, couldn't you just bolt the C cradle right to the top of the roller fairlead?
JKCTAZ is offline
post #5 of 25 Old 03-27-2014, 12:43 PM
Made in the U.S.A.
GenRight Off Road's Avatar
How would you build one different than what we offer?
805-584-8635
GenRight Off Road is offline
post #6 of 25 Old 03-27-2014, 12:49 PM Thread Starter
there is room for sure...not sure how to bolt there. The fairlead is just a pin with a clip that holds it in. Im not knowledgeable about swapping out bolts and whatnot on that part of a winch setup and what you can/cant do.
post #7 of 25 Old 03-27-2014, 12:51 PM Thread Starter
im not sure if I would change anything...do you have one that will work for a 20"?
post #8 of 25 Old 03-27-2014, 12:53 PM
Do you make one for a 20" bar? website says up to 12".
The one that genright makes sandwiches between the winch mounting plate and the fairlead.
post #9 of 25 Old 03-27-2014, 12:54 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
See picture, just drill a hole into the void behind each side roller and bolt the C cradle through it. 2 dollars worth of hardware and done.
JKCTAZ is offline
post #10 of 25 Old 03-27-2014, 12:54 PM
Made in the U.S.A.
How far apart are the bolts on your light? You drill the holes in our mount exactly where you need them. If you click on the link at look at the pics, it may make more sense.
805-584-8635
post #11 of 25 Old 03-27-2014, 12:56 PM Thread Starter
the outer dimensions are 22 1/4". The two holes that I drilled in the Rigid cradle mount is 8.5" apart...so i see what you are saying...combine the cradle mount and your mount....right?
post #12 of 25 Old 03-27-2014, 12:57 PM Thread Starter
Im diggin it. i will go take a look when the phones die down. that may work perfect.
post #13 of 25 Old 03-27-2014, 12:57 PM
Made in the U.S.A.
The light size is really irrelevant.
Its more about where the bolt are on the light you're looking at. IF they're 12" or less apart, then I don't see why it wouldn't work.
805-584-8635
post #14 of 25 Old 03-27-2014, 01:00 PM Thread Starter
the hardware that comes with the light will be no narrower than 20"....so without something to mount it to first I would not be able to mount it directly to the GR mount.
post #15 of 25 Old 03-27-2014, 01:09 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
You would have to mount the C cradle by drilling new holes in it to line up with the foot on the GR plate, but why bolt a bracket to a bracket? Drill two holes through the C cradle and the roller fairlead and leave out an extra part.
JKCTAZ is offline
post #16 of 25 Old 03-27-2014, 01:16 PM Thread Starter
amen.
post #17 of 25 Old 03-27-2014, 01:34 PM
nlgrav182's Avatar
I made my own version of GenRight's bracket for my IPF's by hacking up an old roller fairlead.
OKAY FUCKMOUTH.
nlgrav182 is offline
post #18 of 25 Old 03-27-2014, 01:38 PM Thread Starter
you just earned that tshirt i sent ya..that looks like it will work perfect. if you were closer id buy you a beer.
post #19 of 25 Old 03-27-2014, 01:55 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
JKCTAZ is offline
post #20 of 25 Old 03-27-2014, 04:53 PM Thread Starter
Name:  ImageUploadedByAG Free1395960800.234071.jpg
This may work!
post #21 of 25 Old 03-27-2014, 04:55 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
I think the bracket would have pushed it into the mid hoop...
JKCTAZ is offline
post #22 of 25 Old 03-28-2014, 10:59 AM Thread Starter
Name:  ImageUploadedByAG Free1396025915.974946.jpg
Mounted. I was about 1/8" off on my drilling so light is slightly aimed in to traffic. PERFECT! Thank you guys for the brain storming.
post #23 of 25 Old 03-28-2014, 11:09 AM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
Looks good! Are you going to move the cubes up to the winshield brackets?
JKCTAZ is offline
post #24 of 25 Old 03-28-2014, 11:11 AM
Looks damm good. I would rotate the cubes outwards for a wider angle of light.
post #25 of 25 Old 03-28-2014, 11:19 AM Thread Starter
maybe. they are el cheapo lights and not very long in the distance. might move them under the rear bumper
