Rock Lights - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 03-21-2014, 11:35 AM Thread Starter
sixstring's Avatar
Rock Lights
Anyone use these as rock lights? If I go with these should I get 60 or 180 degree? I plan on using the 11mm. I would rather not drill 7/16" holes anywhere, but I want something secure.
http://www.oznium.com/led-bolt
sixstring is offline
post #2 of 18 Old 03-21-2014, 11:46 AM
I would say the 60 degrees since it will concentrate the light better.
However I would not buy oznium products again. After installing 26 of their superflux, within year half had burned out. Of course they replaced them for free but within another year 13 more had burned out. Maybe these are better but I would pass.
How many do you plan on running?
post #3 of 18 Old 03-21-2014, 11:52 AM Thread Starter
sixstring's Avatar
I was planning on running 10, which would put me at around $65 for the bulbs alone. I found this kit for $55.99 which includes everything, but I don't like how they mount with 3M tape.
http://www.xkglow.com/10_Pod_60_LED_...p/xk061001.htm
post #4 of 18 Old 03-21-2014, 12:12 PM
You can find them cheaper on ebay, search for led pod.
I am currently running these, they are held on with 3m tape and have never come off. Just clean the area real good before you put them on.
http://www.ebay.com/itm/12V-5-X-5-LE...557546&vxp=mtr
post #5 of 18 Old 03-21-2014, 12:39 PM
Rubiconquered's Avatar
How much light are they actually putting out?
Ive seen a few different "kits" that seem to barely put out any light... I want that shit BRIGHT!
CRAWLIN PERFORMANCE 602-552-6793
Rubiconquered is offline
post #6 of 18 Old 03-21-2014, 01:17 PM Thread Starter
sixstring's Avatar
Only 18.4 lm each for the Ozniums, the other kit doesn't specify brightness
post #7 of 18 Old 03-21-2014, 01:26 PM
numb_crna's Avatar
I put three of these lights under the Heep. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Two up front to light across the diff / LCAs: one mounted on my forward air tank (facing down/driver/ rear), one tucked up on the side of my oil skid (facing down / passenger / read). I put the third un the rear, center, where the OE muffler was, facing down to light rear diff.
They throw lots of light-- you can see by the reflection on the snow, and have aluminum housings. Very sturdy!
I am happy.
____________________
Marcus of RCO: "I'm not selling anything, I'm just helping you buy stuff!
numb_crna is offline
post #8 of 18 Old 03-21-2014, 01:44 PM Thread Starter
sixstring's Avatar
I am happy.
Those are bright! but for $20 more I can get the vision x kit
http://www.visionxusa.com/Accent_Lig..._24/index.html
post #9 of 18 Old 03-21-2014, 02:05 PM
I am going to replace all my rock lights, not because they suck but because I want it bright as hell under there. Going to replace with these, if I can get a good price on them.
http://www.ebay.com/itm/221397773496...84.m1426.l2649
post #10 of 18 Old 03-21-2014, 02:07 PM
I wonder how big of a led bar you could mount under the jeep. With the 50's going as low as 500 bucks, I wonder what a 24 inch bar would look like under there.
post #11 of 18 Old 03-21-2014, 02:43 PM
I use this as my pillar lights they are very bright for a cheap led light
muddyman184 is offline
post #12 of 18 Old 03-21-2014, 02:45 PM
bigworm36's Avatar
Hahahahah probably look like a space ship !!
bigworm36 is offline
post #13 of 18 Old 03-21-2014, 03:24 PM
I happen to know where there is a 12 inch bar at that no one will use again.
post #14 of 18 Old 03-21-2014, 03:32 PM
The Vision X kit really isnt that bright
I can get you a steal on a 12-20" bar! lol
post #15 of 18 Old 03-21-2014, 03:37 PM
jku09's Avatar
check out the under-glow.com setup
couple write-ups on pirate
jku09 is offline
post #16 of 18 Old 03-21-2014, 11:33 PM
The OPs light are .5 watts. They cost $5.99 each. I have the same lights but, they are 3 watts for $7 bucks each. I only have ten of these if anyone wants them. By the way, you don't drill a hole for the light to fit into, you make a small L bracket, drill a hole for the light and just screw them down.
dahreno is offline
post #17 of 18 Old 04-30-2014, 06:57 PM
Keith B.'s Avatar
I have Vision X and they are not that bright.
07 JKU, 14 bolt rear/ Teraflex 60 front, Tera Long Arm, King Coilovers, 40" MT/R-Ks, Antirock etc. 430HP LS3 engine swap. Cage and 14 bolt swap thread-
Keith B. is offline
post #18 of 18 Old 05-08-2014, 12:03 PM
Talking
I can get you a steal on a 12-20" bar! lol[/QUOTE]
Go on... Im listening..
LIFN4LO is offline
