Turn signals not self canceling - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 03-19-2014, 09:26 AM Thread Starter
I recently replaced the clock spring on my 2010 JK. Installation was a piece of cake, no major issues, took less than hour. However, now my turn signals (left and right) are not self canceling after a turn. Has anyone experienced this problem? If so, what was the fix??
Wingman is offline
post #2 of 4 Old 03-19-2014, 10:05 AM
ronjenx's Avatar
The clock spring has a turn signal canceling cam on it. On the left control stock there is a tip that extends toward the clock spring when a turn signal is requested.
You either have a bad control stock, (tip not extending), or a bad cam on the clock spring.
It sounds like you need to take it apart to see what's going on.
ronjenx is offline
post #3 of 4 Old 03-19-2014, 10:29 AM Thread Starter
Thanks. I'll check it out this afternoon...
Wingman is offline
post #4 of 4 Old 03-20-2014, 09:25 AM Thread Starter
Removed left control stock and discovered I had installed it incorrectly. The upper and lower grooves on the module were misaligned and were not allowing the tip to engage the cam. Put it back together, everything's working fine. Thanks for the assistance.
Wingman is offline
