Kicker Amp - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 10-18-2009, 01:41 PM Thread Starter
Kicker Amp
Is there a noticeable improvement with the Kicker Amp Upgrade (77KICK33) over the Infinity Amp? Does it improve the sound of the sound bar speakers?
jaburk is offline
post #2 of 7 Old 10-20-2009, 05:04 PM
That Kicker amp is designed for JK's with the base sound system, not as an upgrade for the Infinity system.
If you're looking for an upgrade and improve the soundbar sound a Nitro amp makes a big difference. I heard one back to back in a friend's Unlimited and the difference is very noticeable. Soundbar is louder, midranges are more pronounced, and the bass hit harder.
I have one I was going to put in the for sale section, if you're interested PM me. I bought it to be a "trailblazer" and install it in my base model X but I quickly realized that it would be far less work and I wouldn't have to hack my wiring harness all to heck by using an aftermarket amp.
jkracing37 is offline
post #3 of 7 Old 10-21-2009, 12:18 PM
upgrade base system with factory amp
jkracing,
are you saying that it will be easier to install an aftermarket amp into an x with the base system ? I am looking to upgrade my base system (no amp) with the OEM infinity amp. because I was thinking it would be easier than installing an aftermarket amp. Sounds like you have already looked into this. Thanks
cbuck is offline
post #4 of 7 Old 10-21-2009, 03:14 PM
Yeah, it's definitely WAY easier than trying to make the factory Infinity amp work. I actually bought an Infinity amp and researched all the wiring. I went through the documentation for the factory radio and amp, marked all the wires on the pigtails for the radio and amp, then it was time to start hacking the factory harness to wire everything up. Then I realized that even if I hack my harness up there is a chance that the amp will not be properly recognized by the Canbus. At that point you'd need a Starscan tool change settings to recognize the amp.
With an aftermarket amp you buy a PAC AOEM-CHR3, plug it in to the factory harness and radio, run RCA cables to the amp, power the amp, run speaker wires and you're done. Simple!
post #5 of 7 Old 10-21-2009, 06:36 PM
thanks for info. jkracing ! I suppose I will fab. a bracket for an aftermarket to mount in the factory location, use the PAC adapter and run a power wire and be done. I have been investigating adding the OEM amp. to my base system for weeks. Seems like it should be plug and play with OEM amp.
Also, the 77kick33 is not an upgrade to the factory amp. Although some descriptions do indicate it. It is in fact a 4.1 ch 184 watt kicker amp. packaged by Chrysler with everthing needed mount and plug into factory non-infinity system wiring. I was so confused after reading installation instructions and application guide from www.justforjeeps.com, that I called Kicker direct to confirm.
cbuck is offline
post #6 of 7 Old 10-23-2009, 04:22 PM
factory sub wires
jkracing, did you find where the factory sub woofer wires stopped under the dash. I bought a factory sub and enclosure plugged into factory harness in the rear. There are 2 green (1 with white stripe, 1 with black stripe) and 2 grey (1 with white stripe, 1 with black stripe) at the sub. I haven't found them under dash yet. Thought you may have found them.
cbuck is offline
post #7 of 7 Old 10-23-2009, 06:19 PM
No, I have not traced the wires so I do not know where they terminate. I planned on running a heavier gauge wire back to my sub box.
