CB hook up problem - JKowners.com : Jeep Wrangler JK Forum
post #1 of 18 Old 10-15-2009, 07:32 PM Thread Starter
RUDY850's Avatar
CB hook up problem
Getting engine interference coming threw the cb.And some werd stuf going on with the ingine off.
opening the door taking the key in and out of the ignition. stuff like that.
But this part goes away in a minute or two if the key is left out and the door is closed.Also when tuning the antenna the meter goes to zero on all channels
power from battery
cb ground
mount with ground stap
ground from mount to body
Hook up at cb
I checked all grounds with a test light and they were all good
RK 3.5 LIFT/RRD SHOCKS/FRONT CONTROL ARMS/DRAG LINK/TRACK BAR/REAR BRAKE HOSES/COOPER 295-75-17 STT JEEPERMAN FRONT BUMPER SUPERWINCH EPI9 JKS LOWER TRACK BAR BRACES/DISCONNECTS CRAGAR WHEELS SOFT 8 SYNERGY UPPER TRACK BAR BRACES RR SKID PLATES BENCHMARK DESIGNS EVAP SKID
RUDY850 is offline
post #2 of 18 Old 10-16-2009, 02:39 AM
ka3pit's Avatar
You could try an RF filter in line or tie into the fuse panel instead of the battery.Cant tell what radio that is but some radios have better noise filtering in them also.
Originally Posted by nootherride View Post
for sure... you guys are wound a little tight
.... remember your supposed to stop the q-tip when theres resistance
ka3pit is offline
post #3 of 18 Old 10-16-2009, 06:09 AM
Alter Ego's Avatar
Before you buy a filter, swap in a buddy's radio that doesn't have a noise problem. If his is quiet with your wiring, then you need a noise filter for your radio. Another thing to do is run both ground and power wires twisted around each other or at least parallel to each other all the way to the battery. That way they pick up less interference.
I'm not sure what you mean about the meter going to zero. The SWR meter or the radio meter? What meter setting, SWR, RF power, or REF?
KD8NHC
08 4 Door Rubicon
Member of Two Trackers 4wd Club
Great Lakes Four Wheel Drive Association
United Four Wheel Drive Associations
Alter Ego is offline
post #4 of 18 Old 10-16-2009, 06:41 AM
rdhrd4's Avatar
i am unable to view the pictures so i cant tell where you have the cb mounted... i am guessing tho that you most likely put it down at your feet close to the 4wd lever... if this is the case you can try mounting it elsewhere... ie the top of the dash panel... however, if you dont want to do that then as AE said, wrap the wires around eachother all the way up, buy a filter, oh and... (not trying to sound like an a$$ here) but just making sure youve done everything, check your squelch... good luck!
rdhrd4 is offline
post #5 of 18 Old 10-16-2009, 07:29 AM
The Joker's Avatar
take your ground to the battery. I had the same issue and it fixed mine.
The Joker is offline
post #6 of 18 Old 10-16-2009, 10:20 AM
try running your power from the fuse block instead thats where mine is hooked up
scene: Agaudo smashes cockroach to provoke ventura
Agaudo: Homicide!, ventura how you gonna solve that one?
Ventura: Good question Agaudo,first I'd establish a motive..in this case the killer saw the size of the bugs dick and became insanely jealous!
jkjones is offline
post #7 of 18 Old 10-16-2009, 03:20 PM Thread Starter
RUDY850's Avatar
It is a cobra 29
RUDY850 is offline
post #8 of 18 Old 10-16-2009, 03:28 PM Thread Starter
RUDY850's Avatar
Don't know anybody else with a cb close to me
The cobra 29 has a built in swr meter. after i calibrate the meter it says to switch it to the swr meter mod and then key the mike starting on channel 20. when i do this the needle swings the hole way to the left. 0 it does this on all the channels. i know the lower the number the better but this cant be right
RUDY850 is offline
post #9 of 18 Old 10-16-2009, 03:31 PM Thread Starter
RUDY850's Avatar
squelch is adjusted properly
The cb is mounted in the glove box door
RUDY850 is offline
post #10 of 18 Old 10-16-2009, 03:33 PM Thread Starter
RUDY850's Avatar
The jk only has one fuse box. correct. under the hood near the battery
RUDY850 is offline
post #11 of 18 Old 10-16-2009, 03:36 PM Thread Starter
RUDY850's Avatar
I will try all suggestions when i can. just had surgery on my hand today so it will be awhile till i can mess with it again
Thanks all
Rudy
RUDY850 is offline
post #12 of 18 Old 10-16-2009, 04:55 PM
How and where did you mount your antenna? Good ground connection for the antenna?
2008 JK Rubicon
86ish Formula Toyota
OlMan is offline
post #13 of 18 Old 10-16-2009, 05:09 PM Thread Starter
RUDY850's Avatar
Im using the cool teck gate mount. the ground looks good to me
can you see the pics
RUDY850 is offline
post #14 of 18 Old 10-17-2009, 04:52 AM
disturbedklownz's Avatar
I just mounted a cobra 29 in mine and im having the same problem.Ive tried everything but i read somewhere that it might fix the wine if we ground the cb chassis itself.I havent tried it yet but im going to.Ill let you know if it works
Mine is calibrating right.From what it sounds like yours is not.Take the antenna ground off and just run a non permanent one to the frame bolts right behind the rear tire.They are real easy to get to and my mount instructs me to ground there.I dont think it will fix the wining noise but it will help tune ur cb.
disturbedklownz is offline
post #15 of 18 Old 10-17-2009, 11:40 AM
Yes, I can see the pics, but only paid attention to the first two. My bad.
I installed the hand-held 75WX. Like you I ran the power directly to the battery and used a body ground. My antenna is basically mounted like yours. I would still chase the grounds.
2008 JK Rubicon
OlMan is offline
post #16 of 18 Old 10-17-2009, 11:54 AM
chromedome's Avatar
99% of the time it's a ground problem. A continuity probe is not the same as High current power or RF. So while you may be able to get the probe to light or beep. you probably have stray RF or voltage flying around your electrical system. Either ground back to the battery (usually best) or to metal frame that has paint / powder coating removed down to bare metal. Try to avoid grounding to body panels.
chromedome is offline
post #17 of 18 Old 10-20-2009, 11:25 AM Thread Starter
RUDY850's Avatar
Ok I messed around with this some today.
I now have the power wires twisted to gather and both are going to the battery.Did not help at all
Some things I noticed.
With the antenna disconnected at the radio. Engine running.All the engine noise was gone.But there is static.The static is real bad on channel one and lessons going up to channel 40.If I turn on the NB/ANL switch the static goes away on all channel.The static is also the same with the ingine off
If I disconnect the mic the static goes away. Engine running or not
RUDY850 is offline
post #18 of 18 Old 10-20-2009, 12:35 PM
rdhrd4's Avatar
sounds like a discharge distance problem... try grounding it close to the radio itself... using as little ground wire as possible...
rdhrd4 is offline
