iPod interface with stock sound system (Infiniti) - JKowners.com : Jeep Wrangler JK Forum
post #1 of 17 Old 10-12-2009, 07:52 AM Thread Starter
Ape
Ok, my dealer has no idea what I am looking for, so I will run by you guys. I am wanting an iPod interface that allows you to use the head unit as the iPod control. This would allow me to stow the iPod in the glovebox.
I have a nearly identical head-unit in my Dodge Magnum and it has this interface/cable system. I simply plug the iPod into the connector in the glovebox.
I slid my Jeep's head-unit out this weekend and noticed an empty port in the back. Is this for the iPod connector? If so, does anyone know the part number?
Thanks in advance.
*edit* I do NOT want the FM modulated interface.
Ape is offline
post #2 of 17 Old 10-12-2009, 08:30 AM
You need to tell us what head unit you have, Single, 6 disk, or MyGig RER (GPS) or MyGig Ren (non nav). Once you do that it'll be easier to tell you what parts you need.
SaharaBlackNo1 is offline
post #3 of 17 Old 10-12-2009, 10:04 AM Thread Starter
Ape
It's the single disc, no-Nav. 368W 7-Speaker Infinity Sound System, Uconnect & Sirius.
Ape is offline
post #4 of 17 Old 10-12-2009, 10:29 AM
I'm going to assume that you do not already have the Uconnect Module. So, you'll need part number:
82211878 http://www.justforjeeps.com/cesyuchafr.html
Then you'll also want to order the iPod cable to go with it:
82210787AB http://www.justforjeeps.com/ipinm20.html
Once you've installed them both (do it yourself it's very easy), you'll need to go to the dealer and have them use the StarScan tool to enable uConnect.
Once that's done, you'll have the ability to control your iPod through the head unit, without FM modulation. Here's a good write up on the whole thing:
http://www.jeepforum.com/forum/f96/i...-mygig-497556/
Those part numbers I listed are the latest ones on the just for jeeps site, but double check them to make sure they are what you need.
post #5 of 17 Old 10-12-2009, 10:43 AM Thread Starter
Ape
Sahara... thanks very much for the help!
Ape is offline
post #6 of 17 Old 10-12-2009, 12:14 PM
I have a 2009 rubicon with my gig with nav and want the u connect and ipod control what is needed??
BS
Big Shot is offline
post #7 of 17 Old 10-12-2009, 01:06 PM
GreenAmphibious's Avatar
you could buy a new (READ NICER) aftermarket head unit with IPOD functions for that price
2015 JKU Sport Virgin
GreenAmphibious is offline
post #8 of 17 Old 10-12-2009, 01:13 PM
BS
You've got it much easier than Ape. To enable uConnect all you'll need is the Mopar Mic Kit:
82211743AB http://www.justforjeeps.com/ucmikit.html
and to get your iPod functioning through the MyGig you'll have to also have the MyGig Specific iPod Integration cable:
82211853 http://www.justforjeeps.com/ipodwiring.html
Edit: iPod integration through the MyGig is only available with the 09s and up, for anyone who doesn't know this already.
Oh, BS once you've got the mic you'll need to go into the MyGig settings menu and select "enable JK/VR". You get to the menu by pressing Menu and Seek Up and Seek Down all at once. Be careful when in there to only change the one option as it's been reported that pressing stuff at random in there can brick your mygig.
post #9 of 17 Old 10-13-2009, 07:38 AM
Thanks a lot !!!!!!! I am ordering the parts today!!!
BS
Big Shot is offline
post #10 of 17 Old 10-13-2009, 07:45 AM
Gear's Avatar
OK, my turn please. I have a 2007 Jeep Unlimited with an in dash 6 disc CD player. This is with the Infinity 7 speaker stock set up. I would like to get my ipod controlled thru the head unit as well as charged.
Justin
2006 Adventure Trailers Chaser #15
2007 Jeep Wrangler Rubicon Unlimited(Sold)
2013 Jeep Wrangler Rubicon Unlimited
Gear is offline
post #11 of 17 Old 10-13-2009, 08:31 AM
dsy
dsy's Avatar
You would need the same set up as APE, but some of the 07 radios did not have an active port for ipod control. If you have one that is not active you would have to upgrade to a newer HU.
07 Flame Red Unlimited Rubicon, 5.7 hemi, RCV shafts, 35" KM2's, AEV 3 1/2 lift, , AEV rear swing away Carrier, AEV Snorkel, LoD front bumper with Warn powerplant, 45qt Engel refrigerator / freezer. , Marchal E-Code lamps
DIY Hemi build
dsy is offline
post #12 of 17 Old 10-15-2009, 12:54 AM
JKDoc's Avatar
Or you can do the cheap and easy and simply connect the headphone output to the aux input and control your iPod from the iPod which is sitting right next to the radio or, like mine, on the center console. Costs a few bucks. Does not charge the iPod but a seperate in car charger takes care of that.
We have the controller in Good Wife's Grand Cherokee. It is nice to see the info on the display but my usual use of the iPod is to choose a play list and let her go. I get in trouble trying to drive and searching the contents of the iPod.
That Aux port works pretty good for your CB as well.
"Old age and treachery will overcome youth and skill", Bob Arnett
JKDoc is offline
post #13 of 17 Old 10-17-2009, 07:13 AM Thread Starter
Ape
Doc... that is what I am doing today. It's a hassle. I'd much rather have it in the glovebox (out of sight, out of mind). I am thinking about doing a whole new head unit to take advantage of more features.
Ape is offline
post #14 of 17 Old 10-17-2009, 07:28 AM
dsy
dsy's Avatar
If you go that route you may want to check into one of these units so you can at least use the line out port on your ipod so you get the best sound quality. That way you only have one volume adjustment also which is on the stock head unit.
http://www.sendstation.com/us/produc...neout-usb.html
"This makes the new PocketDock with Line Out an ideal accessory for professional DJ’s, HiFi enthusiasts, and anyone else who would like to take the iPod’s great sound quality to its full potential anytime, anywhere, without interference and distortion from the headphone equalizer and amplifier circuitry"
DIY Hemi build
dsy is offline
post #15 of 17 Old 12-27-2009, 03:06 PM
jg
How can you tell if your port for ipod control is active or not? I have an 07 REQ w/ 6CD and want to figure it out before I buy what I need.
jg is offline
post #16 of 17 Old 12-27-2009, 09:17 PM
ok...
2010 rubi with nav, uconnect, mygig, microphone
all i need is the $79 cable linked above?
this allows the mygig to display ipod info?
2010 Trail Rated Convertible MiniVan
DeepWater Blue
4" Teraflex, 37" BFG's on Spyderlocks.
Chrispy is offline
post #17 of 17 Old 12-27-2009, 09:47 PM
That's correct Chrispy.
