Right turn signal makes fog lights turn off - JKowners.com : Jeep Wrangler JK Forum
post #1 of 3 Old 02-20-2014, 08:55 PM Thread Starter
Attachment 120946Can anyone help here? When I have the fog lights on my 2011 JK on, and I turn the right turn signal on, the fog lights turn off. Has anyone had this problem before? How did they fix it? I don't know anything about wiring. A little more info on this. I just installed the JW Speaker replacement fog lights, and I used an after market wiring harness. I thought it must be the lights or harness causing this, so I uninstalled everyrhing and put back in the factory lights. Still same problem. I think it my be the multifunction switch on the turn signal arm. if I barely brush my finger up against it the lights flicker. I am going to replace the Multi function switch, but would still like to know if anyone else has had this problem.
2011 JKU Pearl Green Natural
7.0 Stroked HEMI VVT conversion
Teraflex Elite LCG 4" Long Arm Suspension System
G2 Dana 60s front and rear with ARB lockers
++++++MUCH MORE+++++++
2005 TJ
1995 YJ work in progresssss
SigChiGuy is offline
post #2 of 3 Old 07-24-2014, 07:04 PM Thread Starter
I have not been able to replace the multifunction switch. Has anyone had success with this?
2005 TJ
post #3 of 3 Old 07-24-2014, 08:00 PM
Demon's Avatar
is the stalk in auto headlamps?
I know Daytime Running Lamps are designed to do this... never paid attention to fog lamps
My best guess would be a resistance problem in the stalk.... this of course is as simple as removing the shroud for the column,remove the retainer screw (torx head IRC) and change the switch
Demon is offline
