New lights question - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 01-28-2014, 11:16 PM Thread Starter
Vaydarade's Avatar
New lights question
So I'm planning to get some auxiliary lights here soon. I was planning on getting my lights from Rigid since everything I have heard about them has been positive so far. I know they are pricey but from what I can tell their quality and durability warrants the price tag.
I was planning on getting the 50" light bar and the dual D-series A-pillar mounts. My question comes into play as to what lights to use in the A-pillar mounts. I was planning on getting a pair of D2 Driving lights and either a pair of D series spot lights or D2 hyperspot lights to compliment them.
I'm just looking for suggestions as to what the second pair of A-pillar lights should be.
Black 2012 MW3 4-door Rubi, Teraflex 2.5" lift, Rugged Ridge Wheels, Goodyear Duratrac 35s, Smittybilt XRC GEN2 front and rear bumper, fender armor and rock rails, Custom Grille wrap-Kryptek Typhon Camo, Warn 10-S Zeon Platinum, EVO Full-Protek Skid plates, Cobra 29 LX CB Radio, MetalCloak Fender liners, HIDProjectors Lights, S-pod, Genesis Offroad Dual battery kit, Rigid Industries 50" Light bar
Vaydarade is offline
post #2 of 6 Old 01-29-2014, 12:26 AM
Landoom's Avatar
My KC pillar mount lights are almost worthless with my 50" light bar. Try that out first, then decide if you need more light. They are insane. I just have a cheap knock off from ebay, but I am very pleased with it.
If it ain't broke, don't fix it. If you don't like it, go break it!
'07 JKRU
3.5" RK X-Factor Lift on 37x12.5x17 MTR-K's wrapped around AEV Pintler Wheels
Landoom is offline
post #3 of 6 Old 01-29-2014, 02:38 AM
I have this setup 50" E-Series LED Light Bar (white LEDs) all Spot and D-Series Flood pair (white LEDs)...I highly recommend the Rigid Industries LED lights and i feel they are at the highest quality possible and worth the price tag...
I have this setup mainly due to the type of off-roading i do which is high-speed off-roading and dune bashing so i thought the all spot on the E-Series would be more beneficial to cover as much distance as possible and the floods on the D-series are just to have wider angle light.
If you need any further info i will be glad to share what i have with you.
Sultan T is offline
post #4 of 6 Old 01-29-2014, 04:26 PM
tribal636's Avatar
Check out the Black Box Logistics lights also, they are a little cheaper than Rigid and still use the same CREE LEDs. The Black Box 50" is almost 1k cheaper than the Rigid. I have the 12" spot/flood combo on my winch and love it. The thing lights up my neighborhood.
tribal636 is offline
post #5 of 6 Old 01-30-2014, 08:45 AM
if you get a dual a-pillar bracket, i recommend the one from genesis off road. you can adjust either light in any direction you want. you aren't forced to have it facing only forward. I have the dually D2 spot's on the bottom mount facing forward, and the dually d2 wide facing to the front quarter panel left and right side. I have no need for a 50" light bar as with those 4 lights, my JW Speaker Head lights and the Rigid 10" E-series light bar on my bumper, I have enough light to see what I need. But I highly recommend the genesis off road bracket instead of the RI one.
Mathie84 is offline
post #6 of 6 Old 01-30-2014, 08:56 AM
I got a 50 LED bar and mounting Brackets from Bad Apply Fab, and it is a crazy amount of light. I can't imagin needing more light than that, only problem is you really can't use it for normal driving. I am considering some flush mount LED fog lights for every day use.
neil.cross is offline
