HELP! - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 01-02-2014, 01:04 AM Thread Starter
HELP!
Hello! I turned on my 07 Jeep Wrangler and the windshield wipers are now on and won't turn off.Also, there are no turn signals, brights, or wiper fluid. what happened? And more importantly, how do i fix it?
Jinc98313 is offline
post #2 of 2 Old 01-03-2014, 04:29 PM
chapco's Avatar
Exclamation help
I have seen other people having this issue in the past too.
I recall that removing negative wire to the battery for a few minutes (after making sure all wiper and signal arms are in off state) and reconnecting solves it.
However you will need to reset your radio clock and stations.
if that doesn't help you may want to check the ground on the drivers side headlight is clean and fully connected as there has been some discussion of bad ground on headlight triggering wiper motor since they are on a similar lead.
chapco is offline
