Receiver/Speaker Upgrade & Subwoofer Installation - JKowners.com : Jeep Wrangler JK Forum
post #1 of 6 Old 01-01-2014, 03:17 AM Thread Starter
Send a message via Skype™ to codemaster94
Post Receiver/Speaker Upgrade & Subwoofer Installation
Hi guys,
I plan on getting my whole stereo system changed in time and I was just curious what your recommendations were.
  • RECEIVER
= What Receiver I would need to keep Uconnect/Bluetooth/Radio Controls for my steering wheel working and in use with the new Stereo? I've been looking into this: http://www.crutchfield.com/p_113KDCX...7.html?tp=5684
and using this as an adaptor. It'll keep everything but Uconnect: http://www.crutchfield.com/p_541RP4C...r.html?tp=3486
  • SPEAKERS
= What speaker size should I get? I know 6 1/2"s are the right size, but will I have to put in new brackets or anything to hold them in place? Going for all genres. I've noticed that my Roll Bar Right speaker has been "rattling" or vibrating or something. Here's what I've been looking at these but can't decide: http://www.crutchfield.com/App/Produ...=01|130TSA1605
  • SUBWOOFER
= What subwoofer would work best to stay out of the way of things, but still sound heavy? I listen to every genre so I'm looking for an all-rounder type of subwoofer. One that I can show off to my friends for rap, one that doesn't sound too bass-heavy for Rock/Pop. I've been looking at this: http://www.crutchfield.com/p_1369451...ox.html?tp=113
I'm not so sure on what to do for an amp. Any recommendations? I'll have the 4 speakers in the front and roll bar, along with the 2 tweeters on the dash. I'll also have a sub, so that's about 5-7 channels? Once again, I'm not too sure on that.
All recommendations would TREMENDOUSLY help me in the long run. Thanks again guys!
2014 Jeep Wrangler "JK" 2-door Sport
-Jeep Wrangler Tire Cover
-Legal Tint on Driver/Passenger, 15% on Hardtop windows
codemaster94 is offline
post #2 of 6 Old 01-01-2014, 06:30 AM
warcop's Avatar
Send a message via Yahoo to warcop
My humble recommendation,
First, if you want to follow the pack use the search function in the upper right corner of the screen.
Second, it looks like you used quotes to post hyperlinks (clicking on them does not work).
Third, refer to the methods used on here as a base and build it like you want it.
Warcop
2012 JKU Sport, Rock Krawler 2.5 Flex, Smittybilt SRC Side Armor, Mesh Grille MOD, Sony Double DIN AV Receiver, Back up Camera, Kicker Speaker Upgrade, ARB Twin Compressor, Dominion Off Road High Lift Mount, Homemade Paracord Grab Handles, Nitto Trail Grapplers, Paramount Rear Bumper with Tire Carrier, KC Hilites Daylighters, under seat lock box, Metal Cloak Front Bumper, BARTACT Seat Covers, BARTACT Sun Shade, x20 Comp Winch, sPOD, ARB Air lockers, 4.10 Gears.
warcop is offline
post #3 of 6 Old 01-01-2014, 08:26 AM
I am a JL guy so see my sig for specifics. . . . though I will tell you a HUGE difference once new wires were ran and speakers were amp'd. Also, 7.7" Marine speakers were a PERFECT fit for the soundbar.
2009, 2 Door X, Rancho 4" Sport Lift w/ 9000xl shocks, 35" Firestone Destination MTR on Spidertrax spacers Bulldog Front Bumper w/XRC8 Winch, LoD Rear Bumper, FinishLineWest Rock Sliders, 5.13 G2's, ARB Rear diff cover, LineX'd tub, JL Clean Sweep, JL 900/5 Amp, JL C5 components in front, JL Marine MX-770's in soundbar, JL FS-110 Marine sub, Tuffy security deck, HID's in Cibie's, Piaa 520s
DanNEBTD is offline
post #4 of 6 Old 01-02-2014, 09:13 PM
Cochepaille's Avatar
My ipad deleted my reply 1/2 way through typing a huge reply, so you're getting the abridged version now, lol. I used to design sound systems for people, though... PM me if you want further guidance.
Head unit - entirely dependent on budget. Alpine makes a couple nice ones at a reasonable price that you can use your current mic and steering wheel controls, and you'll also get a better nav system and DVD capability. Expect to pay $600-900, though.
Speakers - any 6.5" speakers will work, but some will require a mounting plate for the rear sound bar. Kicker makes a plug-n-play speaker set, which can be found on Quadratec's website, although they are overpriced. You'll be better off picking your speakers after you pick your 4-channel amp as that will determine how much power you'll have to play with (see below). If your budget allows, look into Alpine speakers - crystal clear quality.
Tweeters - I've always hated how aftermarket tweeters sound when powered through an amp, so one trick I've always used is to run the tweeters through the head unit power as opposed to splicing into the front speakers, which are powered through the amp. You can keep the stock tweeters, but you might as well look for a set of 6.5" speakers sold with tweeters... it'll only set you back about $10 extra, and the clarity is worth it.
Amps (yes, plural) - a 5-channel amp is pretty uncommon, and 6-channel amps aren't really designed to run 4 speakers and a sub (usually 4 speakers and 2 6x9's). A better bet is to get a 4-channel amp to run your 6.5's and a mono amp to drive your sub(s). In either case, you'll want an AMP that has as much RMS power as your speakers/subs have max power (ie. if your 4 speakers combined are 600w max, you should have a 600w RMS 4-channel amp). Don't be fooled my the max wattage numbers... always look at RMS first. As far as brands, stay away from Rockford, Bolt, or any other Best Buy stuff... do your research and get a JL, Kicker, or Alpine within your budget. Same goes for the mono amp.
Sub - if you have the stock sub, it's an 8", and it's nothing special. A 10" sub would be what you're looking for... enough bass for the rap songs, but not so much that you have to lower it for rock/pop. You can look into buying a box for a 10" sub, or if you're good with fiberglass, it would be cheaper to make one... very tedious, though.
BTW, I'm totally skipping the wiring, capacitors, and other odds and ends that will have to be taken into consideration... long story short, just realize that you're opening up a huge can of worms if you're looking to power your speakers externally.
Good luck!
Tyler R. - Ansonia, CT
Silver '12 JKRU
6-speed, soft top, 2.5" TF Lift, 35" Treadwright Guard Dogs, Smittybilt SRC front bumper, Superwinch TS9500 winch, M.O.R.E. oil pan/trans skid, Skid Row exhaust loop skid, Dominion evap relocation,*Smittybilt Oversized Tiire Carrier and Cibie headlights.
Cochepaille is offline
post #5 of 6 Old 01-05-2014, 07:52 AM
Monster Jk's Avatar
Feedback: 23 reviews
I bought some after market RF speakers and wired them into the sound bar. On top of that, I took out the old sub and installed a JL stealth box and Sony 1000w amp. It sounds great. Plus having the head liners on my hard top, it takes a lot of vibration out. Now I just need to do the fronts.
Monster Jk is offline
post #6 of 6 Old 01-06-2014, 10:14 AM Thread Starter
Question
I've heard good things and bad things about the Headliners...What are you using, and what are your pros and cons about them?
