Wiring Rigid Duallys together - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 12-26-2013, 06:31 PM Thread Starter
Tat2dfreak's Avatar
I put 4 rigid dually D2's on a rigid quad windshield mount and wired 2 together on each side so I only have one switch. All 4 turn on but after about 30 seconds one starts to flicker and goes out. Pretty sure all connections are good but thinking I may need to wire them differently. Any thoughts.
Tat2dfreak is offline
post #2 of 7 Old 12-26-2013, 07:05 PM
R.I.P. Mr. Nibbles!
JKCTAZ's Avatar
What size primary are you supplying power with?
JKCTAZ is offline
post #3 of 7 Old 12-26-2013, 07:07 PM
WINNAR!
DOOKEY's Avatar
Yes.
How did you wire the current setup?
One switch should trigger both relays. Both relays pull power directly from the battery.
Andy
316.337.5311
DOOKEY is offline
post #4 of 7 Old 12-26-2013, 07:14 PM
Random Dude
My first thoughts are all questions:
  • Do you know what gage of wire you need for the (2.5 amps x 4 lights =) 10 amp draw?
  • Are you running adequate gage wire?
  • Are you running through a relay?
  • Are your lights "wired together" in series or parallel?
More information is needed, but it's probably something simple. Of course, simple could mean re-doing everything you've done already.
Please provide more information or photos of what you've done.
Originally Posted by DOOKEY View Post
Yes.
One switch could trigger one relay, and that one relay could feed 4 D2s no problem, assuming you used correctly sized wire, etc.
ExWrench is offline
post #5 of 7 Old 12-26-2013, 07:19 PM
WINNAR!
DOOKEY's Avatar
ORRRRR.... you could have one switch wire one relay and that relay kicks on the other relay that kicks on the other relay that puts power directly to the horn.
Pssst.... your lime is showing.
Andy
316.337.5311
DOOKEY is offline
post #6 of 7 Old 12-26-2013, 07:34 PM Thread Starter
Tat2dfreak's Avatar
I'm using the harness that came with the lights, I cut the connectors off the other harness and spliced into one harness. So I'm guessing I should have used both relays to power them, so i'll have to redo that.
I am also waiting on an sPOD.
post #7 of 7 Old 12-26-2013, 07:53 PM
WINNAR!
DOOKEY's Avatar
That is the easiest option when using the stock harness. Just wire the switch to both relays.
Andy
316.337.5311
DOOKEY is offline
