Aftermarket Heated Seats - JKowners.com : Jeep Wrangler JK Forum
post #1 of 9 Old 12-04-2013, 07:33 AM Thread Starter
I have a 2013 JKU Rubicon with cloth seats. I want to put heated seats in the jeep and have a couple of questions.
  1. Where did you put the switches? (pics please)
  2. Can you put the switch in the factory location by drilling a hole?
  3. Is there anything you need to get when you pull the seat cover off to install the pads?
  4. Can you purchase the factory switches or wiring harness?
I am thinking of purchasing these and the switch is a round switch.
http://www.amazon.com/dp/B00355MTEW/...=IWTNM4D2UNELN
Thanks for any help
EDIT:
I actually found this write up so I will look into this more
http://www.jk-forum.com/forums/jk-wr...lation-172773/
bradbeyer is offline
post #2 of 9 Old 12-04-2013, 07:38 AM
Recent thread on a similar topic that might answer a few questions for you. Not quite your OEM switch questions though.
https://www.jkowners.com/forum/showthread.php?t=139801
post #3 of 9 Old 12-04-2013, 08:42 AM
A JKO DICK
ASSFROW's Avatar
Don't think you need to worry about spending the extra for waterproof. Here are the ones I posted in the other thread. It's a kit for both seats.
http://www.amazon.com/Seats-Carbon-F...332320-1773834
There are some kits on ebay with square switches that have a dial to adjust heat. Maybe those switches will fit in the stock spot, but I dunno.
ASSFROW is offline
post #4 of 9 Old 12-04-2013, 09:03 AM
TCdawg's Avatar
the pic on Amazon makes it look like there is only one pad for each seat. Is that correct or is there a pad for the seat and seat back for each seat?
TC
TCdawg is offline
post #5 of 9 Old 12-04-2013, 09:04 AM
Looks like the picture is defining what is included for one seat. Then they are selling you two of that. Pic also has one relay, one switch, etc..Each seat has its own switch and relay too.
post #6 of 9 Old 12-04-2013, 09:05 AM
TCdawg's Avatar
10-4
TC
TCdawg is offline
post #7 of 9 Old 12-02-2015, 03:56 PM
Just finished the install of heated seats in my 2011 JKU. Thanks to everyone in this forum and others for the great write-upsÖ.. probably wouldnít have attempted it without all that. Just wanted to give my thoughts on the project:
I bought the Sports Imports Universal kit from Amazon. $83 for bottom and back pads for both seats. There were cheaper universal kits available, but this kit had great reviews on other forums. I thought the quality of the kit and the detail of the instructions was excellent, especially for the price.
http://www.amazon.com/gp/product/B00...ilpage_o02_s00
Quadratec sells a kit with plug and play wiring from Check Corp for around $200. I was going to purchase this, until I saw it only comes with a back pad for the passenger seat due to the airbag sensor thatís adhered to the seat foam. Since my normal passenger was the motivation for this whole project (canít drive around with no top if the lady is cold)Ö.this wasnít an option.
I decided to just cover up the sensor with the heating pad; the airbag warning alarm works just as it did before when there is weight on the seat. The pads from my kit allowed you to cut a section out of the middle for the sensors as long as 1.5 inches remained on each side of the cut. There is more than enough room to make the cut if thatís your preference.
I tried removing the 18mm seat bolts with a Ĺ drive breaker bar (I may have a hernia as a result). Instead, I removed the six 13mm nuts that hold the seat sliders to the lower seat frame (nuts facing down). The two forward, inboard nuts need to be turned with a wrench, the others can be done with a deep well socket.
Battery had been disconnected for a while. I separated all connectors under the seat, disconnected the seat belts from the seat (torx bit) and brought them inside. I unbolted the seat backs from the bottoms (4 bolts). Iíve heard some people say they did the install with the seats still in the Jeep. IMO, there is no way to get everything straight, wrinkle-free, and trimmed / cut properly without pulling the seats apart.
Removing the seat covers enough to install the pads is very easy. All you need is a small putty knife or pry tool to help the fabric clips off the seat frame. There are no hog rings, you can cut 1 zip tie on each seat bottom if you want easier access, and all the clips go back on easy.
The bottom heat pad has to be trimmed about 2 inches because of the sill (pleat that goes across the seat approx 6 inches back from the front edge). The back pad needs no trimming. They ask you to cut out a notch in the seat back foam for the thermostat (a small bump about 1/8 high, Ĺ wide, and 1 inch long). I did not do this and canít feel it at all when seated.
Wiring was easy. 20mm hole for each round switch (I placed them in the area in front of the cupholder and behind the shifter boot (manual trans). Wires run on either side of the center console. Removing two bolts towards the rear of the center console allows you to lift it up enough.
Each seat has a positive and negative power wire, and a control cable that connects to the switch. I used the 3í switch extensions that came with the kit to make for tidy wiring (you could get away without if you didnít mind the switch wiring exiting the seat midway and directly entering the center console.
Both grounds were spliced together and attached to an existing body ground terminal under the inboard section of the driverís seat. For now, I brought power from the SPOD through the fire wall, under the driverís door sill, and spliced it to both seat power wires under the driverís seat carpet.
I was going to attempt to find the accessory wire that is behind the cigarette lighter in the dash till I saw this product that taps into accessory power without having to break into the factory harness. This will eliminate the need to throw both the SPOD switch and the actual seat heater switch.
http://www.quadratec.com/products/96080_9801.htm
The project took about 7 hours and a 6 pack. It was really cool to do this myselfÖ. and it was a toasty ride to work in the morning. Looking forward to an extended top-down season!
CMHilbert is offline
post #8 of 9 Old 12-03-2015, 08:51 AM
I have Corbeau seats in my 2 door with heaters in them. I put the switches in the dash between the vents and the window switches. Ill try and remember to get some pictures in a little while.
kg6bws is offline
post #9 of 9 Old 12-14-2015, 09:04 AM
Sorry to piggyback your thread - but I installed these in the BACK seat for the kids in our JKU. went in pretty easy.. I did have a question - seems to shut off and I'm wondering if that is because of the thermostat?
Thank you,
Alex
amarzano is offline
