Back up lights, install question? - JKowners.com : Jeep Wrangler JK Forum
post #1 of 8 Old 11-24-2013, 08:58 PM Thread Starter
I just put on a new rear bumper that has cut outs for the factory fog lights. Trying to decide best way to wire them in?
1. I have a pillar spod with 3 spots on it, so I could wire to it and have to flip the switch to turn them on.
2. Wire into the reverse lights so its automatic every time I go into reverse.
3. Wire into the factor fog light harness and use the factory fog light switch to turn them on.
Pros and cons of each way?
The pros of 1 and 2 is if someone is being a dbag and tailgating I can turn them on while in drive
ShizNizy is offline
post #2 of 8 Old 11-24-2013, 09:05 PM
TXCAJN's Avatar
I wired mine to a switch because I prefer to choose when they are on/off, independent of anything else.
2012 JKU Altitude
2014 Grand Cherokee Overland
TXCAJN is offline
post #3 of 8 Old 11-24-2013, 09:07 PM
ADDICTION II build begins....
TXROCK's Avatar
Speaking from personal experience with the 4 LEDs I have on the rear bumper wired in as additional backup lights: I would recommend wiring them into the switch pod you have so you can turn them on and off when you need them.
U.S. Army
TXROCK is offline
post #4 of 8 Old 11-24-2013, 09:18 PM
Tight_wad's Avatar
I have mine wire so that I can either flip a switch or when I shift into reverse. Both 1 & 2. There a write on here somewhere on how to do it.
Sent from AutoGuide.com App
Tight_wad is offline
post #5 of 8 Old 11-24-2013, 09:38 PM
I just wired mine into the reverse lights. Switch later when it warms up. It's not that bright to fool with IMHO. it is bright, but dealable.
YellowIH is offline
post #6 of 8 Old 11-25-2013, 06:17 PM
Banshee's Avatar
I used a relay and 2 switches. I have one that will turn them on when reverse is selected & the other is just on at any time.
Switch 1 goes from reversing lights to relay trigger, switch 2 is from permanent power to relay trigger. Then just permanent power to relay main for the rear floods. I put the relay just under the carpet in the back corner near where the cage comes down.
Originally Posted by Clone7
When you die, you see your life going by in a flash.
Steve Jobs didn't - Apple doesn't support Flash.
This message has been reviewed & approved by the NSA, Google and Microsoft.
Banshee is offline
post #7 of 8 Old 11-25-2013, 06:21 PM
I wired mine to a switch where that useless bag clip was.
Mcdowell11290 is offline
post #8 of 8 Old 11-25-2013, 06:48 PM
Acey's Avatar
I have mine wired to a switch so I can turn them on as needed.
(i.e. hooking up the trailer at night, camping, d'bag tailgating, etc..)
2008 JK Rubi on big tires and stuff, RIPP supercharger.
Various dents and scratches.
Acey is offline
