Bumper Light Help - JKowners.com : Jeep Wrangler JK Forum
post #1 of 7 Old 11-15-2013, 04:35 PM Thread Starter
desertdog702's Avatar
Bumper Light Help
I got a different bumper for the front of my 2012 JKU and had to remove the OEM fogs since the new bumper didn't have the cut outs. I want to get some new lights on the bumper and use the OEM connectors so I can use the OEM fog lamp switch on the stem. Has/does anyone know of a kit that uses the OEM connectors, I heard that KC has one but I found nothing except for a 2009 OEM.
Thanks!
ΜΟΛΩΝ ΛΑΒΕ
desertdog702 is offline
post #2 of 7 Old 11-18-2013, 04:23 PM Thread Starter
No one have any ideas?
ΜΟΛΩΝ ΛΑΒΕ
post #3 of 7 Old 11-18-2013, 05:21 PM
Thanks!
You can still use the OEM switch on the steering column. I put RI Dually D2's in mine. They flicker when the key is turned, but instant on/off when I want. Don't limit yourself to the OEM connector. Cut that bitch off and solder/crimp what you need to add to make it work.
Mathie84 is offline
post #4 of 7 Old 11-18-2013, 09:15 PM
Acey's Avatar
Like Mathie said. I have installed KC SlimLites to the windshield, and PSC back-up lights into the rear bumper via separate light switches. I know there are some threads out there about the same idea you have, just do a search, you'll find them.
The S-POD is also something you may wish to look into (caution: $ticker $hock!).
2008 JK Rubi on big tires and stuff, RIPP supercharger.
Various dents and scratches.
Acey is offline
post #5 of 7 Old 11-19-2013, 10:15 AM
kkuntz01's Avatar
If you're looking for a complete plug and play solution in your factory fog location without hacking up the factory wiring, there is this from VisionX.
Vision X JK LED Fog Light Kit
kkuntz01 is offline
post #6 of 7 Old 11-19-2013, 10:47 AM
sixty5vdub's Avatar
Here is what I did. I decided to fab up a connector that would plug into the stock wiring, using a cut up stock foglight bulb.
Been working perfectly for 2+ years.
https://www.jkowners.com/forum/showthread.php?t=53300
AMP
AMP
sixty5vdub is offline
post #7 of 7 Old 11-20-2013, 12:58 PM Thread Starter
Hey thanks all, still doing homework, Ill post up details once I get it.
ΜΟΛΩΝ ΛΑΒΕ
