Factory mygig Nav unit conversion - JKowners.com : Jeep Wrangler JK Forum
post #1 of 11 Old 11-12-2013, 11:40 AM Thread Starter
can some please tell me if it is possible to put in a factory mygig nav radio in my 2008 unlimited that currently has your standard radio
and what other parts i will need to make it work or programing
how many people have done this? is it worth doing i found a radio for $600
and im getting mix statements from the dealers
SilverMonster is offline
post #2 of 11 Old 11-12-2013, 01:59 PM
Jonboy's Avatar
I know that at a minimum you'll need to know the security code - the units were tied to the vehicle's VIN. Not sure how you can go about getting that code, presumably from a dealer, but if you hook it up it will ask for the code when it powers up.
Jonboy is offline
post #3 of 11 Old 11-12-2013, 06:22 PM
Comfortably Numb
RubiCajun's Avatar
for one thing you need to make sure the one you have is a hi-speed because it's the only one that works in a jk. It needs to be the RER model. you also need the correct amp to go with it. if you don't have it the amp out of a dodge nitro will work in the wrangler and improve the sound quality. the dealer will have to flash it for you in order to get it working. you will also need the correct satellite (for GPS) and sirius antenna's. If you don't know what you're doing bring it to a dealer.
RubiCajun is offline
post #4 of 11 Old 11-13-2013, 04:35 AM
OH9JK's Avatar
I did that in my 2009...
My Jeep came from the factory with Sirius/AM/FM/single CD head unit.
I replaced it with a RER head unit (high speed bus). I had to also purchase the GPS antenna and Uconnect microphone. (links below). Bluetooth and Uconnect are built into the headunit. The GPS antenna installs under the center dash cover (directly above the headunit) and the microphone can go anywhere you want...it comes with a long cable and double stick tapes to any flat surface.
** If your current headunit does not have Sirius then you will also need to purchase a satellite antenna **
It was all plug and play. No dealer involvement needed. The only thing I had to do was go into the engineering mode on the RER (press seek up, seek down and menu at same time) and "enable JK microphone".
That's it...just that simple.
http://www.justforjeeps.com/rergpsantenna.html
http://www.justforjeeps.com/ucmikit.html
OH9JK is offline
post #5 of 11 Old 11-15-2013, 01:02 AM
jkfamilypride's Avatar
Nailed it bro!
+1
2010 Jeep Sahara black 4DR
-AFE CAI
-Throttle body spacer
-KC windshield slim lites
IRAQ AND AFGHANISTAN COMBAT VETERAN 2006-2012
jkfamilypride is offline
post #6 of 11 Old 11-15-2013, 10:48 AM
Victim Of Pain's Avatar
I am on my second mygig unit in my 2008, came installed from the factory. If I had to do it all over again I would go aftermarket. The first mygig in my Jeep would not power on every so often, then after driving for a little while the lights would flash and then come on. Seemed to be always when I needed the nav. Had it repalaced under warranty and my new one is still doing the same thing. When this thing shits the bed I will be replacing with a better unit.
Victim Of Pain is offline
post #7 of 11 Old 11-15-2013, 10:49 AM
Ohh yeah, and the screen peels off after a while. Especially after getting wet in a rain storm.
post #8 of 11 Old 11-20-2013, 07:45 PM
TJT
TJT's Avatar
I swapped the 6disk radio my 09 came with out for an Mygig unit. It was great, integrated seamlessly, but honestly there are newer, less expensive options that are leaps and bounds better that you can go with. And they too are just as simple to install.
Your 08 does not have the microphone cables behind the dash so you'll need the kit from MOPAR (and there's others that would work too.) I highly recommend the Lock Pick. Unlocking all the features is worth it and will save you a lot of frustration as you get used to what you can do with it.
One thing I did not like about the MyGig was the way it organized music stored on the HDD. Its useless and impossible to navigate on the fly.
I chose to get away from the nav radio in the jeep and went with a single-din Kenwood Multimedia deck and have a Cobra CB unit underneath it. DOn't miss the MyGig one bit. I just use my iPad for navigation.
TJT is offline
post #9 of 11 Old 11-21-2013, 03:58 PM
cpayne41's Avatar
Not to jack this thread or anything but is there a fix for this? my 2010 is peeling and I can't seem to make it look any better.
2010 JKUR Red, 4" Teraflex Mid Arm with 9550 shocks, Procomp 7033's wrapped in 35" KM2's, Ace front and rear bumpers, Ace sliders, rigid duallys in front and rear bumpers, trekwerx hudrack with 30" black box logistics light bar, 5.38 gears, axles gusseted, teraflex hood shocks.
cpayne41 is offline
post #10 of 11 Old 11-21-2013, 04:19 PM
Besides replacing the unit? no idea of a fix. Don't really see it when the radio is on.
post #11 of 11 Old 11-21-2013, 04:24 PM
cpayne41's Avatar
Yeah thats what I've read so far. Its not that just annoying at times.
cpayne41 is offline
