Rear ORFAB led bumper wiring - JKowners.com : Jeep Wrangler JK Forum
post #1 of 2 Old 11-03-2013, 10:47 PM Thread Starter
I tapped into the rear backup light per bump instructions for now.
I want to wire in an SPDT switch with one relay to have it turn on with reverse, off or on at will.
I did a lot of wiring when I did a frame off on my Scout II. I've forgotten a bit.
Help appreciated.
I need a one relay wiring diagram with an SPDT switch please. A simple one.
I think I can tap into the harness at the drivers area from searching.
Thanks.
YellowIH is offline
post #2 of 2 Old 11-07-2013, 06:53 PM
usmcdoc14's Avatar
so you want the control of:
on with switch
off with switch
on with reverse
off with switch even in reverse?
I am assuming not the last one.
easiest would be diode on the hot from both the switch and the factory reverse (line toward relay) to the switching wire for the relay. normal wiring for everything else. The diodes will prevent burning out stuff and allows it to be reverse switched or switch switched.
usmcdoc14 is offline
