Viair wiring to sPOD - JKowners.com : Jeep Wrangler JK Forum
post #1 of 4 Old 11-02-2013, 01:19 PM Thread Starter
Question Viair wiring to sPOD
Hi:
I have a question on wiring a Viair 400C compressor (30amp) to an sPOD source
Would I use the fuse and relay of the sPOD, eliminating the Viair fuse and relay or do I wire and use the fuse and relay supplied by Viair.
Smokem is offline
post #2 of 4 Old 11-02-2013, 02:27 PM
JohnnyWalker's Avatar
I just used the sPOD relay/fuse on my setup. If you have a pressure switch, don't forget to attach it to the positive terminal on the sPOD, or it won't work correctly.
JohnnyWalker is offline
post #3 of 4 Old 11-02-2013, 06:19 PM
don't mean to hijack but how would two 400c compressors be wired into the spod?
thinking of viairs 2on2 OBA 150 psi kit.
njbeachrat is offline
post #4 of 4 Old 11-04-2013, 05:12 AM Thread Starter
That did it. Working fine now.
Smokem is offline
